0013564 | ParaView | (No Category) | public | 2012-10-24 21:05 | 2015-01-11 08:32 | ||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013564: For Exodus datasets, never bring up in outline mode | ||||||||
Description | For Exodus datasets, we probably should never bring up the dataset in outline mode. Every single time the first thing the user will do is go to surface. For very large data, LOD desimation works fine. Or, add this as a user defined state variable, default to surface. | ||||||||
Project | Sandia | ||||||||
Topic Name | 13564_fix_unstructured_data_outline_defaults | ||||||||
Type | feature | ||||||||
(0029511) Utkarsh Ayachit (administrator) 2012-10-25 11:01 |
commit 583592448b7a38a54609682b409c8559f135e6c3 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Oct 25 10:58:08 2012 -0400 BUG 0013564. Increase the unstructured data outline threshold. To address the issue in BUG 0013564, we increase the unstructured data outline theshold to 250 million cells. 0.5 million cells used previously was too low for pratical use-cases anyways. Change-Id: I6ccfe46fb99d450b19af3703778d73ac4d7f980d |
(0029556) Utkarsh Ayachit (administrator) 2012-10-29 10:50 |
merged into master, if applicable. |
(0029573) Alan Scott (manager) 2012-10-29 15:47 |
Tested with Whipple_shield_32. Remote server, Linux, master. |
2012-10-24 21:05 | Alan Scott | New Issue | |
2012-10-25 11:01 | Utkarsh Ayachit | Topic Name | => 13564_fix_unstructured_data_outline_defaults |
2012-10-25 11:01 | Utkarsh Ayachit | Note Added: 0029511 | |
2012-10-25 11:01 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-10-25 11:01 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-10-25 11:01 | Utkarsh Ayachit | Resolution | open => fixed |
2012-10-25 11:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-10-29 10:50 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-10-29 10:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-10-29 10:50 | Utkarsh Ayachit | Note Added: 0029556 | |
2012-10-29 15:47 | Alan Scott | Note Added: 0029573 | |
2012-10-29 15:47 | Alan Scott | Status | customer review => closed |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2015-01-11 08:32 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 00f1b915 |
2015-01-11 08:32 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 58359244 |
