0013511 | ParaView | (No Category) | public | 2012-10-11 11:59 | 2015-01-11 08:32 | ||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013511: CS_KITS not being processed when plugin doesn't have servermanager files. | ||||||||
Description | The following plugin code doesn't work. --------------------------------------------------- add_paraview_plugin(SomeName "0.1" SERVER_MANAGER_XML SomeName.xml CS_KITS vtkMyModule ) target_link_libraries(SomeName vtkMyModuleCS) --------------------------------------------------- It never ends up initializing the CS streaming for the classes in the module vtkMyModule. However, if we passed in SERVER_MANAGER_SOURCES, then it works as expected. The generated plugin code skips the initialization of external CS modules unless the plugin itself embeds some classes to CS wrapped. | ||||||||
Project | Kitware | ||||||||
Topic Name | 13511_fix_plugins | ||||||||
(0029363) Utkarsh Ayachit (administrator) 2012-10-11 12:04 |
commit 94831b64504535256acebf585330d0a8a0fc90a3 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Oct 11 12:00:08 2012 -0400 BUG 0013511. CS_KITS are now processed even when no sources are provided. Fixed BUG 0013511. CS_KITS are now processed even when no sources are provided. The CS_KITS will still be ignored if no xml is provided as well, but that can be fixed at a later date. Change-Id: I1fe4723db3d84576dde6678413068dc4b63ff9ca |
(0029382) Utkarsh Ayachit (administrator) 2012-10-15 11:51 |
merged into master, if applicable. |
(0029438) Alan Scott (manager) 2012-10-19 13:24 |
Trusting that fix is correct. |
2012-10-11 11:59 | Utkarsh Ayachit | New Issue | |
2012-10-11 12:04 | Utkarsh Ayachit | Topic Name | => 13511_fix_plugins |
2012-10-11 12:04 | Utkarsh Ayachit | Note Added: 0029363 | |
2012-10-11 12:04 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-10-11 12:04 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-10-11 12:04 | Utkarsh Ayachit | Resolution | open => fixed |
2012-10-11 12:04 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-10-15 11:51 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-10-15 11:51 | Utkarsh Ayachit | Note Added: 0029382 | |
2012-10-15 11:52 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-10-19 13:24 | Alan Scott | Note Added: 0029438 | |
2012-10-19 13:24 | Alan Scott | Status | customer review => closed |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2015-01-11 08:32 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 9f726423 |
2015-01-11 08:32 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 94831b64 |
