0013499VTK(No Category)public2012-10-09 10:002014-10-02 15:43
Reportermneugeba2
Assigned ToCory Quammen
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version6.1.0
Summary0013499: VTK 5.10: vtkPlane: projectVector function rescales the plane normal
DescriptionWhen using the projectVector function of an vtkPlane instance, the normal vector of this instance is rescaled (i.e. length is unequal to 1).
The reason for this is the usage of vtkMath::MultiplyScalar(normal, dotProd); in the implementation of the projectVector function. This rescales the normal-vector of the plane. I recommend to use a copy of the normal-vector for MultiplyScalar instead of the original double[3]. A simple vtkMath::normalize(normal) afterwards wouldn't do the job, since the normal could be flipped.
TagsNo tags attached.
ProjectTBD
Typeincorrect functionality
 Relationships
  Notes
(0031061)
Dave DeMarle (administrator)
2013-06-25 14:12
Thanks. Would you mind submitting the suggested fix in gerrit to facilitate automated testing and review?
For details on how to do so see http://www.vtk.org/Wiki/VTK/Git/Develop [^]
(0033530)
Cory Quammen (developer)
2014-10-02 15:43
Fixed in commit:
commit ba3c24c3f0739718a482d2f8e8f33f024bcbf8cf
Author: David Gobbi <david.gobbi@gmail.com>
Date: Tue Jul 30 22:26:03 2013 -0600
    ProjectVector method was modifying plane normal.
    Thanks to David Jarvis for pointing out this bug. Projecting a vector
    would cause the plane's normal to be multiplied by the dotprod of the
    plane and the vector (in some cases, causing the normal to become zero).
    Obviously the ProjectVector() function should not modify the normal.
    Change-Id: Idaa86fdad897777a65fba6f8ac5309a3582175e6
 Issue History
2012-10-09 10:00 mneugeba2 New Issue
2013-06-25 14:12 Dave DeMarle Note Added: 0031061
2014-10-02 15:43 Cory Quammen Note Added: 0033530
2014-10-02 15:43 Cory Quammen Status backlog => closed
2014-10-02 15:43 Cory Quammen Assigned To => Cory Quammen
2014-10-02 15:43 Cory Quammen Resolution open => fixed
2014-10-02 15:43 Cory Quammen Fixed in Version => 6.1.0
