0013473 | ParaView | (No Category) | public | 2012-09-25 16:50 | 2015-01-11 08:29 | ||||
Priority | urgent | Severity | minor | Reproducibility | have not tried | ||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013473: Variable name change to Material volume fraction in CTH | ||||||||
Description | There has been a code change to Material volume fraction in CTH. It is now called Volume Fraction. The following git diff shows the changes to the code that I made: [wascott@S919535 ...ParaViewCore/VTKExtensions]$ git diff vtkSpyPlotUniReader.cxx diff --git a/ParaViewCore/VTKExtensions/vtkSpyPlotUniReader.cxx b/ParaViewCore/V index 0439800..74377a3 100644 --- a/ParaViewCore/VTKExtensions/vtkSpyPlotUniReader.cxx +++ b/ParaViewCore/VTKExtensions/vtkSpyPlotUniReader.cxx @@ -130,12 +130,15 @@ vtkSpyPlotUniReader::~vtkSpyPlotUniReader() this->SetCellArraySelection(0); } -#define READ_SPCTH_VOLUME_FRACTION "Material volume fraction" +#define READ_SPCTH_VOLUME_FRACTION_OLD "Material volume fraction" +#define READ_SPCTH_VOLUME_FRACTION_NEW "Volume Fraction" //----------------------------------------------------------------------------- int vtkSpyPlotUniReader::IsVolumeFraction(Variable* var) { - return strncmp(var->Name, READ_SPCTH_VOLUME_FRACTION, - strlen(READ_SPCTH_VOLUME_FRACTION)) == 0; + return ( (strncmp(var->Name, READ_SPCTH_VOLUME_FRACTION_OLD, + strlen(READ_SPCTH_VOLUME_FRACTION_OLD)) == 0) || + (strncmp(var->Name, READ_SPCTH_VOLUME_FRACTION_NEW, + strlen(READ_SPCTH_VOLUME_FRACTION_NEW)) == 0) ); } //----------------------------------------------------------------------------- | ||||||||
Project | Sandia | ||||||||
Topic Name | 13473_fix_cth_variable_names | ||||||||
Relationships | ||||||
(0029284) Alan Scott (manager) 2012-09-25 16:52 |
This must be fixed for the 4.0 release. |
(0029323) Alan Scott (manager) 2012-10-04 16:08 |
Replaced by 13492. Instead of adding a new variable name as listed, we are going to remove the need to figure out if variables are material volume fraction. |
(0029913) Utkarsh Ayachit (administrator) 2012-12-19 13:57 |
commit 601a8ced2a8361c6edfa71744c636ec8485991ed Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Dec 19 13:55:33 2012 -0500 BUG 0013473. Update code to detect volume fraction variables. There has been a code change to Material volume fraction in CTH. It is now called "Volume Fraction". This commmit updates the vtkSpyPlotUniReader to detect both new and old names for the variables and treat them as volume fraction variables. Change-Id: Ie23ed055cc60dc8cb040a25590a958bddcde6df9 |
(0029914) Utkarsh Ayachit (administrator) 2012-12-19 14:00 |
The CTH filters treat any Unsigned-Char cell array as volume fraction array and work on them. The reader's role is to detect the appropriate array as volume fraction array and down-convert those to unsigned char. Hence we indeed need the reader to detect these arrays correctly. The commit uses a regular expression to detect both variables name styles (old and new). |
(0029928) Utkarsh Ayachit (administrator) 2012-12-21 11:21 |
merged into master, if applicable. |
(0030022) Alan Scott (manager) 2013-01-08 19:07 |
Looks good. Tested remote server, Linux, master. |
2012-09-25 16:50 | Alan Scott | New Issue | |
2012-09-25 16:52 | Alan Scott | Note Added: 0029284 | |
2012-09-25 16:52 | Alan Scott | Assigned To | => Alan Scott |
2012-09-25 16:52 | Alan Scott | Status | backlog => todo |
2012-09-25 17:06 | Utkarsh Ayachit | Assigned To | Alan Scott => Utkarsh Ayachit |
2012-10-04 16:06 | Alan Scott | Relationship added | related to 0013492 |
2012-10-04 16:08 | Alan Scott | Note Added: 0029323 | |
2012-10-04 16:08 | Alan Scott | Status | todo => closed |
2012-10-04 16:08 | Alan Scott | Resolution | open => won't fix |
2012-12-19 13:57 | Utkarsh Ayachit | Status | closed => backlog |
2012-12-19 13:57 | Utkarsh Ayachit | Resolution | won't fix => reopened |
2012-12-19 13:57 | Utkarsh Ayachit | Topic Name | => 13473_fix_cth_variable_names |
2012-12-19 13:57 | Utkarsh Ayachit | Note Added: 0029913 | |
2012-12-19 13:57 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-12-19 13:57 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-12-19 13:57 | Utkarsh Ayachit | Resolution | reopened => fixed |
2012-12-19 14:00 | Utkarsh Ayachit | Note Added: 0029914 | |
2012-12-21 11:20 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-12-21 11:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-12-21 11:21 | Utkarsh Ayachit | Note Added: 0029928 | |
2013-01-08 19:07 | Alan Scott | Note Added: 0030022 | |
2013-01-08 19:07 | Alan Scott | Status | customer review => closed |
2013-01-30 10:41 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
2015-01-11 08:29 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 982e5259 |
2015-01-11 08:29 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 601a8ced |
