0013464ParaView(No Category)public2012-09-21 15:142016-08-12 09:59
ReporterUtkarsh Ayachit
Assigned ToUtkarsh Ayachit
StatusclosedResolutionmoved
PlatformOSOS Version
Product Versiongit-master
Target Version4.0Fixed in Version
Summary0013464: Prism: Threshold bounds on Z axis are incorrect
DescriptionSteps:
1. Load Prism Plugin.
2. Click on the "Rainbow" icon, labelled "Open SESAME Surface".
3. Open CuStPene2/CuSt_Sesame_mat_1.301
4. Close the 3D view, we are only interested in the Prism view.
5. On the properties panel, in the "Warp Surface" group, change the variable to "Total EOS (Pressure).
6. Apply and reset camera. You should see almost-planar surface.
7. Using same steps now open CuStPene2/CuSt_Sesame_mat_2.301, with "Total EOS (Pressure) for the "Warp Surface" and show it in the same view.
8. You will now see two surfaces in the same view.
9. Click on "Change View Scale" in the Prism toolbar, look at the ranges for each axis, everything looks good.
10. Now change the X threshold for both the reader to be 8000-9000 and hit Apply, you'll see both the surfaces shrink.
11. Now go to the "Change View Scale" dialog, the X-Axis "Threshold Bounds" have indeed updated to reflect our custom range 8000-9000. The Z-axis threshold bounds however, are still unchanged. They should have changed since Z-axis is dependent on the X/Y ranges. -- That's the BUG to fix.
12. Also, as one changes the active source between the two Prism sources, the Threshold values reset back to the full range (and the Apply button goes green). --- That's another BUG to fix.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0038255)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2012-09-21 15:14 Utkarsh Ayachit New Issue
2012-09-21 15:14 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2012-09-21 15:27 Utkarsh Ayachit Status backlog => todo
2012-10-18 14:05 Utkarsh Ayachit Target Version => 4.0
2012-10-30 11:49 Sebastien Jourdain Assigned To Utkarsh Ayachit => Sebastien Jourdain
2012-10-30 11:49 Sebastien Jourdain Status todo => active development
2012-10-30 12:59 Sebastien Jourdain Assigned To Sebastien Jourdain => Utkarsh Ayachit
2012-10-30 12:59 Sebastien Jourdain Status active development => todo
2016-08-12 09:59 Kitware Robot Note Added: 0038255
2016-08-12 09:59 Kitware Robot Status todo => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
