0013458 | ParaView | (No Category) | public | 2012-09-17 16:44 | 2013-05-18 20:00 | ||||
Reporter | Kyle Lutz | ||||||||
Target Version | Fixed in Version | 4.0 | |||||||
Summary | 0013458: Add Separators For the Properties Panel | ||||||||
Description | Add support for adding separators to the properties panel. | ||||||||
Tags | New Panels | ||||||||
Project | TBD | ||||||||
Topic Name | refactor_panels | ||||||||
(0030594) Utkarsh Ayachit (administrator) 2013-04-22 17:25 |
This was referring to adding 'Grouping' capabilities for properties on the panel. With the following commit, panels can group properties (look the the Display properties for 3D data or the Properties for Wavelet source). commit 17a9b733b119c44780fc10e153e0606e26101dd4 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Apr 12 12:05:25 2013 -0400 Refactoring Properties Panel (pqPropertiesPanel). This commit refactors pqPropertiesPanel for better usability and visual appearance. The changes can be summarized as follows: - Added a new class, pqProxyWidget, which creates the 'auto-generated' panel for any proxy. pqPropertiesPanel now uses this class to create the panels for source/display. - Property group were extended to add ability to group properties on non-exposed properties (as demonstrated by Wavelet source). The visual appearance of property groups was also changed. Also fixed leaks in ServerManager relating to groups and new property attributes that were added in past for the panels. - pqPropertyWidgetDecorator was added to provide a mechanism to add custom logic to widgets which having to create new widget types. pqPropertyWidgetDecorator can be used to control widget visibility, for example. - Converted custom panels for for several filters to be non-custom i.e. simply be auto-generated. - Added mechanism for plugins to provide new pqPropertyWidget types for properties, property groups or new pqPropertyWidgetDecorator types. Added an example under Examples that demonstrates the use of the same. - Added infrastructure to print debug messages when certain environment variables are set (pqDebug). - Removing obsolete SummaryPanel elements. - Updated tests to work with these changes. Change-Id: I49e82525ba666380b265a7f2075207dc2cd6f452 |
(0030619) Utkarsh Ayachit (administrator) 2013-04-25 09:24 |
SUMMARY --------------------------------------------- Topics merged into master: 13450_update_tests_to_use_new_panels (VTK) 14023-plot3d-function-support 14026_catalyst_python_warning 14032_fix_CoProcessingTestInput fix_protobuf_try_compiles pvw-python-refactoring pvw-remove-example refactor_panels (VTK) update_vtk_master zoom-to-data-icon fix_cmake_2.8.10_plugins_issue |
(0030652) Alan Scott (manager) 2013-04-30 20:20 |
Developer tag in Git. Also, I tested this refactoring with closing other bugs. |
2012-09-17 16:44 | Kyle Lutz | New Issue | |
2012-09-17 16:44 | Kyle Lutz | Assigned To | => Kyle Lutz |
2012-09-17 17:30 | Kyle Lutz | Tag Attached: New Panels | |
2012-09-17 17:30 | Kyle Lutz | Status | backlog => todo |
2012-09-17 17:30 | Kyle Lutz | Status | todo => active development |
2013-04-22 17:23 | Utkarsh Ayachit | Assigned To | Kyle Lutz => Utkarsh Ayachit |
2013-04-22 17:25 | Utkarsh Ayachit | Topic Name | => refactor_panels |
2013-04-22 17:25 | Utkarsh Ayachit | Note Added: 0030594 | |
2013-04-22 17:25 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2013-04-22 17:25 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-04-22 17:25 | Utkarsh Ayachit | Resolution | open => fixed |
2013-04-25 09:22 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-04-25 09:24 | Utkarsh Ayachit | Note Added: 0030619 | |
2013-04-25 09:24 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-04-30 20:20 | Alan Scott | Note Added: 0030652 | |
2013-04-30 20:20 | Alan Scott | Status | customer review => closed |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
