0013426 | ParaView | (No Category) | public | 2012-09-05 11:26 | 2015-01-11 08:31 | ||||
Platform | Mac | OS | OS Version | ||||||
Target Version | 4.0 | Fixed in Version | 3.98.0 | ||||||
Summary | 0013426: TextEdit boxes in Animation View get too small | ||||||||
Description | If the Animation View window is not large enough, the TextEdit widgets for Time, Start Time, and End Time become so thin as to be unusable. Attached is a screen capture of these widgets from my Mac build when the Animation View is brought up with the default window layout. So, the first part of the fix would be to set the minimum width of these boxes to be at least one character wide. The second part of the fix would be to make a bit more room for these widgets. The No. Frames SpinBox is at least twice as wide as I imagine most applications will ever need. Also, the lock buttons could be changed to square tool buttons like that used for the "advanced" button in the Properties panel. That would serve the double purpose of making the widgets more narrow and to better indicate their toggle behavior. | ||||||||
Project | Sandia | ||||||||
Topic Name | 13426_cleanup_animation_view_toolbar | ||||||||
Attached Files | AnimationViewTop.png [^] (10,062 bytes) 2012-09-05 11:26
(0029433) Utkarsh Ayachit (administrator) 2012-10-18 23:57 |
commit b36b7d180f51e23eb98473eb935368a76cc5b2f8 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Oct 18 23:55:55 2012 -0400 BUG 0013426. CLeaning up animation view header. 1. Fixed minimum widths for all LineEdits. 2. Changed No. Frames spin-box to line edit so it would take up less space. 3. Converted buttons to tool-button 4. Tweaked padding and spacing to better use available space. Change-Id: I8d2d8fccc3b7bdfc3f996dfbc2192574f50b74f6 |
(0029470) Utkarsh Ayachit (administrator) 2012-10-22 10:51 |
merged into master, if applicable. |
(0030044) Alan Scott (manager) 2013-01-09 16:04 |
Looks good. Tested remote server, Linux, master. |
2012-09-05 11:26 | Ken Moreland | New Issue | |
2012-09-05 11:26 | Ken Moreland | File Added: AnimationViewTop.png | |
2012-09-05 11:27 | Ken Moreland | Platform | => Mac |
2012-10-09 09:27 | Sebastien Jourdain | Assigned To | => Kyle Lutz |
2012-10-18 14:05 | Utkarsh Ayachit | Target Version | => 4.0 |
2012-10-18 23:57 | Utkarsh Ayachit | Topic Name | => 13426_cleanup_animation_view_toolbar |
2012-10-18 23:57 | Utkarsh Ayachit | Note Added: 0029433 | |
2012-10-18 23:57 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-10-18 23:57 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-10-18 23:57 | Utkarsh Ayachit | Resolution | open => fixed |
2012-10-18 23:57 | Utkarsh Ayachit | Assigned To | Kyle Lutz => Utkarsh Ayachit |
2012-10-22 10:51 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-10-22 10:51 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-10-22 10:51 | Utkarsh Ayachit | Note Added: 0029470 | |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2013-01-08 21:22 | Alan Scott | Project | TBD => Sandia |
2013-01-09 16:04 | Alan Scott | Note Added: 0030044 | |
2013-01-09 16:04 | Alan Scott | Status | customer review => closed |
2015-01-11 08:31 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 889d06d8 |
2015-01-11 08:31 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master b36b7d18 |
