0013370 | ParaView | (No Category) | public | 2012-08-17 13:43 | 2013-01-16 22:31 | ||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013370: Make "make install" work correctly on mac. | ||||||||
Description | "make install" should generate an App bundle on mac. | ||||||||
Project | Kitware | ||||||||
Topic Name | fix_mac_install_rules | ||||||||
(0029015) Utkarsh Ayachit (administrator) 2012-08-17 13:44 |
commit a67c39f6044474967e7ae6fa530dede66fe53512 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Aug 16 17:27:53 2012 -0400 Fixing install rules on Mac to build ParaView.app. If building on apple, we will set cmake rules for ParaView such that "make install" will result in creation of an application bundle by default. The trick we play is as such: 1. We hide the CMAKE_INSTALL_PREFIX variable at force it to a internal/temporary location. All generic VTK/ParaView install rules happily go about installing under this CMAKE_INSTALL_PREFIX location. 2. We provide a new vairable MACOSX_APP_INSTALL_PREFIX that user can set to point where he wants the app bundle to be placed (default is /Applications). 3. We set CMAKE_INSTALL_NAME_DIR to point to location of runtime libraries in the app bundle. Thus when the libraries are installed, cmake automatically cleans up the install_name paths for all shared libs that we built to point to a location within the app. 4. To make packaging of plugins easier, we install plugins under a directory named "plugins" in the temporary CMAKE_INSTALL_PREFIX location. This just a simple trick to avoid having to keep track of plugins we built. 5. Every application that builds an app, then uses the ParaViewBrandingInstallApp.cmake or something similar to put all the libraries, plugins, python files etc. within the app bundle itself. 6. Finally, the bundle generated under the temporary location is copied over to the path specified by MACOSX_APP_INSTALL_PREFIX. In keeping with our "WE INSTALL WHAT WE BUILD" rule, this app bundle is not distributable to others since it does not include Qt, or other external dependencies. For a distributable pacakage, refer to ParaView Super-build instructions. Change-Id: Id731a00df84c1161f7ec9a13bf2c774de0b4c829 |
(0029025) Utkarsh Ayachit (administrator) 2012-08-17 14:27 |
merged in master, if applicable |
(0030168) Alan Scott (manager) 2013-01-16 22:31 |
Developer tag in git. Closing. |
2012-08-17 13:43 | Utkarsh Ayachit | New Issue | |
2012-08-17 13:43 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-08-17 13:44 | Utkarsh Ayachit | Topic Name | => fix_mac_install_rules |
2012-08-17 13:44 | Utkarsh Ayachit | Note Added: 0029015 | |
2012-08-17 13:44 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-08-17 13:44 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-08-17 13:44 | Utkarsh Ayachit | Resolution | open => fixed |
2012-08-17 14:26 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-08-17 14:27 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-08-17 14:27 | Utkarsh Ayachit | Note Added: 0029025 | |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2013-01-16 22:31 | Alan Scott | Note Added: 0030168 | |
2013-01-16 22:31 | Alan Scott | Status | customer review => closed |
