0013326ParaView(No Category)public2012-07-25 20:522015-01-11 08:31
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PriorityhighSeverityminorReproducibilityhave not tried
StatusclosedResolutionfixed
PlatformOSOS Version
Product Versiongit-master
Target Version4.0Fixed in Version3.98.0
Summary0013326: Crash parallel extract selection with
Description8 pvservers, Linux, master.
Open z_pinch1.exo.8.[0-7]. All vars on. Apply.
Filters/ process ID scalars. Apply.
-Z
Select cells on. Select cells from one of the processor areas. I am using the upper right, light orange area.
Filters/ Extract Selection. Apply.
Filters/ Histogram. Apply.
Crash.
Output, server side, is as follows:
ERROR: In /projects/viz/paraview/src/ParaView/3.16.0-junk/ParaView3/ParaViewCore/VTKExtensions/vtkExtractHistogram.cxx, line 197
vtkPExtractHistogram (0xbe7bb60): Failed to locate array to process in composite input.
vtkPExtractHistogram (0x1b930a10): Failed to locate array to process in composite input.
vtkPExtractHistogram (0x30dcaf0): Failed to locate array to process in composite input.
vtkPExtractHistogram (0x1a067fd0): Failed to locate array to process in composite input.
vtkPExtractHistogram (0x117be510): Failed to locate array to process in composite input.
vtkPExtractHistogram (0x1fc517a0): Failed to locate array to process in composite input.
vtkPExtractHistogram (0x1c4c3d70): Failed to locate array to process in composite input.
TagsNo tags attached.
ProjectSandia
Topic Name13326_fix_parallel_extract_histogram
Typecrash
 Relationships
  Notes
(0029428)
2012-10-18 17:17
The bug is not with Extract Selection but with "Extract Histogram" filter. Seems like that filter is not working correctly for composite datasets with partial arrays.
(0029435)
2012-10-19 12:16
commit 007503344f792265a2bd5a2ce470a772bd26f7ea
Date: Fri Oct 19 12:13:12 2012 -0400
    BUG 0013326. Fixed segfault in vtkPExtractHistogram in parallel.
    Cleaned up the logic to determine the range for the bins. The logic was
    confusing and hence must have missed some corner case which was causing
    segfaults. This undoes an earlier commit to communicate the name of for the
    "bin_extents" array since that array name is no longer picked based on the array
    that was chosen, it doesn't made much sense to communicate that information
    anyways.
    Change-Id: Ifcf74b8e541dfebb06b4d204c0edff70dd8372f2
(0029466)
2012-10-22 10:51
merged into master, if applicable.
(0029479)
Alan Scott (manager)
2012-10-22 18:47
Tested remote server, Linux, master.
 Issue History
2012-07-25 20:52 Alan Scott New Issue
2012-10-18 14:11 Utkarsh Ayachit Target Version => 4.0
2012-10-18 17:17 Utkarsh Ayachit Note Added: 0029428
2012-10-19 12:16 Utkarsh Ayachit Topic Name => 13326_fix_parallel_extract_histogram
2012-10-19 12:16 Utkarsh Ayachit Note Added: 0029435
2012-10-19 12:16 Utkarsh Ayachit Status backlog => gatekeeper review
2012-10-19 12:16 Utkarsh Ayachit Fixed in Version => git-next
2012-10-19 12:16 Utkarsh Ayachit Resolution open => fixed
2012-10-19 12:16 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2012-10-22 10:51 Utkarsh Ayachit Fixed in Version git-next => git-master
2012-10-22 10:51 Utkarsh Ayachit Status gatekeeper review => customer review
2012-10-22 10:51 Utkarsh Ayachit Note Added: 0029466
2012-10-22 18:47 Alan Scott Note Added: 0029479
2012-10-22 18:47 Alan Scott Status customer review => closed
2012-10-29 17:04 Utkarsh Ayachit Fixed in Version git-master => 3.98.0
2015-01-11 08:31 Utkarsh Ayachit Source_changeset_attached => ParaView master 89b03d8b
2015-01-11 08:31 Utkarsh Ayachit Source_changeset_attached => ParaView master 00750334
