0013292ParaView(No Category)public2012-07-02 20:342016-08-12 09:59
ReporterNathan Fabian
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0013292: Wrong extents in Spyplot reader and corresponding in the AMR filters.
DescriptionIn vtkAMRDualContour.cxx each reference to GetExtents(extent) is immediately followed by
  --extent[1];
  --extent[3];
  --extent[5];
This appears to be due to the Spyplot reader always passing the dimensions as the higher value instead of dimensions - 1.
There is code to select between dimensions-1 and dimensions as the upper extent. I think this should instead be dimensions-2 and dimensions-1 and then vtkAMRDualContour should no longer decrement.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0038240)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2012-07-02 20:34 Nathan Fabian New Issue
2016-08-12 09:59 Kitware Robot Note Added: 0038240
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
