0013273ParaView(No Category)public2012-06-27 18:012016-08-12 09:59
Reportervoncasec
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version3.14.1
Summary0013273: Unstructured grid does not load, slice origin resets to 0.25,0.25,0.25 coordinate when loading pvsm
DescriptionSteps needed to recreate bug.
1. Load a legacy VTK file containing an unstructured grid
2. Create Slice
3. Toggle eye so the unstructured grid and the slices are not rendered
4. Save Paraview state file
5. Disconnect from current session
6. Load .pvsm file created above.
7. Select slice and Review data
Properties tab shows origin of 0.25,0.25,0.25
Information tab indicates number of cells/points/memory: 0/0/0 MB
8. Select unstructured grid layer and review data
It appears as if the unstructured grid does not load when opening a state file if all elements associated with that layer (e.g. slices) are turned off. The user can not do any further processing or visualization of this layer or any subsequent layers.
If the same steps above are repeated, but the eyes are all toggled on before saving the state file, than everything loads correctly when opening the Paraview state file.
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
-  Notes
(0038233)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
- Issue History
2012-06-27 18:01 voncasec New Issue
2016-08-12 09:59 Kitware Robot Note Added: 0038233
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
Powered by Mantis Bugtracker
