0013056 | ParaView | (No Category) | public | 2012-04-04 09:37 | 2013-01-30 10:41 | ||||
Reporter | Matthias Zenker | ||||||||
Product Version | 3.14 | ||||||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013056: Selection with Crtl key not possible | ||||||||
Description | It is not possible any more to select points, then select some more points holding down the Ctrl key, as it was in 3.12-RC2. | ||||||||
Project | Sandia | ||||||||
Topic Name | 13056_fix_selection_issue | ||||||||
(0028428) Robert Maynard (developer) 2012-04-04 14:32 |
I was able to replicate the selection bug with the 32bit binaries on my Windows 7 x64 machine. I get the following output: Generic Warning: In ..\..\..\..\src\ParaViewCore\ServerManager\vtkSMPropertyHelper.cxx, line 399 Call not supported for the current property type. The bug doesn't happen when I use the 64bit binaries. Targetting 3.14.2 |
(0029670) Matthias Zenker (reporter) 2012-11-08 05:15 edited on: 2012-11-08 05:17 |
The bug is still there in 3.98.0-RC1 (Windows 32 bit). I get the following warning when attempting to add points to the selection by holding the Crtl key: Generic Warning: In C:\DBD\pvs-x32\paraview\src\paraview\ParaViewCore\ServerManager\Core\vtkSMPropertyHelper.cxx, line 408 Call not supported for the current property type. |
(0029677) Alan Scott (manager) 2012-11-08 13:08 |
Setting to Sandia, since this effects us also. |
(0029678) Alan Scott (manager) 2012-11-08 13:09 |
This functionality really needs to be fixed. |
(0029713) Alan Scott (manager) 2012-11-14 13:58 |
I also have replicated this bug on Windows. It works correctly on Linux. can.exo, selecting cells on, windows, master (probably just after 3.98.0-RC1) |
(0029740) Utkarsh Ayachit (administrator) 2012-11-16 12:28 |
commit 5fd8a9be5abd779553a890c002c9db4baf56859c Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Nov 16 12:26:29 2012 -0500 BUG 0013956. Fixing selection issues with 32-bit builds. The problem surfaced when sizeof(vtkIdType) == sizeof(int). Change-Id: I20ff1c25c279d4c58f508f768149fd347a40fa34 |
(0029756) Kyle Lutz (viewer) 2012-11-20 12:16 |
Merged into ParaView-master (if applicable) |
(0030011) Alan Scott (manager) 2013-01-08 18:21 |
Tested Windows (and Linux), local server, master. |
2012-04-04 09:37 | Matthias Zenker | New Issue | |
2012-04-04 14:32 | Robert Maynard | Note Added: 0028428 | |
2012-11-08 05:15 | Matthias Zenker | Note Added: 0029670 | |
2012-11-08 05:17 | Matthias Zenker | Note Edited: 0029670 | |
2012-11-08 13:08 | Alan Scott | Project | TBD => Sandia |
2012-11-08 13:08 | Alan Scott | Note Added: 0029677 | |
2012-11-08 13:09 | Alan Scott | Note Added: 0029678 | |
2012-11-08 13:09 | Alan Scott | Status | backlog => todo |
2012-11-14 13:58 | Alan Scott | Note Added: 0029713 | |
2012-11-16 12:28 | Utkarsh Ayachit | Topic Name | => 13056_fix_selection_issue |
2012-11-16 12:28 | Utkarsh Ayachit | Note Added: 0029740 | |
2012-11-16 12:28 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-11-16 12:28 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-11-16 12:28 | Utkarsh Ayachit | Resolution | open => fixed |
2012-11-16 12:28 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-11-20 12:16 | Kyle Lutz | Status | gatekeeper review => customer review |
2012-11-20 12:16 | Kyle Lutz | Note Added: 0029756 | |
2012-11-20 13:57 | Kyle Lutz | Status | customer review => gatekeeper review |
2012-11-20 16:01 | Kyle Lutz | Status | gatekeeper review => customer review |
2013-01-08 17:05 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-01-08 18:21 | Alan Scott | Note Added: 0030011 | |
2013-01-08 18:21 | Alan Scott | Status | customer review => closed |
2013-01-30 10:41 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
