0013023ParaView(No Category)public2012-03-22 14:262016-08-12 09:59
ReporterMatt Mosby
Assigned ToKitware Robot
PriorityhighSeverityminorReproducibilityhave not tried
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version3.10.1
Summary0013023: Integrate filter yields different results in client-server mode
DescriptionUsing the integrate filter to integrate variables over the volume yields different results when running in client-server mode with different numbers of server nodes. The results are also changed by integrating after applying the D3 filter.
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
-  Notes
(0038166)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
- Issue History
2012-03-22 14:26 Matt Mosby New Issue
2016-08-12 09:59 Kitware Robot Note Added: 0038166
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
Powered by Mantis Bugtracker
