0013022 | ParaView | (No Category) | public | 2012-03-22 08:05 | 2016-08-12 09:59 | ||||
Reporter | Paul Edwards | ||||||||
Assigned To | Cory Quammen | ||||||||
Summary | 0013022: bug coloring lines | ||||||||
Description | Lines will only be colored correctly by a scalar value if the solid color is set to white. To demonstrate: * Line Source -> Apply * Calculator -> coordsX -> Apply * Set color to Solid, change to black * Set color to Result and it still shows as black This effects any lines and was noticed in the output from the streamtracer. Note: this seems to mask the scalar color with the solid color, e.g. try choosing red instead. | ||||||||
Project | TBD | ||||||||
(0036679) Cory Quammen (developer) 2016-08-04 15:05 |
Utkarsh fixed this a while back. Tested ParaView 5.1, Mac OS X, built-in server. |
(0038165) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-03-22 08:05 | Paul Edwards | New Issue | |
2016-08-04 15:05 | Cory Quammen | Note Added: 0036679 | |
2016-08-04 15:05 | Cory Quammen | Status | backlog => customer review |
2016-08-04 15:05 | Cory Quammen | Resolution | open => fixed |
2016-08-04 15:05 | Cory Quammen | Assigned To | => Cory Quammen |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038165 | |
2016-08-12 09:59 | Kitware Robot | Status | customer review => closed |
2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
