0013003ParaView(No Category)public2012-03-15 11:372016-08-12 09:59
ReporterMattijs
Assigned ToCory Quammen
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version3.12
Summary0013003: save data format does not include legacy vtk
DescriptionIt seems I cannot save part of a Group DataSets in legacy vtk format.
- generate e.g. a sphere (Sources->Sphere)
- File->Save Data includes legacy vtk format
now group this:
- Select sphere only
- Filters->Group DataSets
and extract sphere only
- Filters->Extract Block
- File->Save Data does not include legacy vtk format
Or maybe the question should be how to extract the Polygonal Mesh from a Multi-block Dataset.
Mattijs
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
-  Notes
(0028385)
Sven Buijssen (reporter)
2012-03-22 16:20
The VTK legacy format does not support multi-block data sets.
Have a look at the script Berk posted on the mailing list some time ago:
http://markmail.org/message/eijjldmejdi6dtgm [^]
It auto-extracts all blocks of a multi-block dataset as-is.
Use the script e.g. in a Programmable Filter, must convenient if that one is turned into a custom filter. Works in builtin as well as client-server mode.
(0028387)
Mattijs (reporter)
2012-03-23 10:10
Thanks for your answer.
Is there any chance of a built-in filter that does this?
(0036680)
Cory Quammen (developer)
2016-08-04 15:10
No, there is no built-in filter that performs this functionality.
There are no plans to add a VTK legacy writer for multiblock data sets, so we can close this issue.
(0038158)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
- Issue History
2012-03-15 11:37 Mattijs New Issue
2012-03-22 16:20 Sven Buijssen Note Added: 0028385
2012-03-23 10:10 Mattijs Note Added: 0028387
2016-08-04 15:10 Cory Quammen Note Added: 0036680
2016-08-04 15:10 Cory Quammen Status backlog => customer review
2016-08-04 15:10 Cory Quammen Resolution open => no change required
2016-08-04 15:10 Cory Quammen Assigned To => Cory Quammen
2016-08-12 09:59 Kitware Robot Note Added: 0038158
2016-08-12 09:59 Kitware Robot Status customer review => closed
2016-08-12 09:59 Kitware Robot Resolution no change required => moved
Powered by Mantis Bugtracker
