0012967ParaView(No Category)public2012-02-28 15:002016-08-12 09:59
ReporterAnn Moulding
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version3.14
Summary0012967: Calculator choking on data with "text" fields.
DescriptionUsing a series of CSV files (and running Table to Points and 2DDelaunay polygon filters successfully on the files) I try using the Calculator filter to create vectors to plot with the Glyph tool. But when I use the calculator – one of the “Point Data” fields (arrays) is not numeric – and when I write my formula (which does not use the non-numeric field) and hit “Apply” - the Output message says
ERROR: In ..\..\..\..\source\VTK\Graphics\vtkArrayCalculator.cxx, line 304
vtkPVArrayCalculator (000000000B39EAE0): Invalid array name: 'Name'
(the name of the non numeric field is “Name”).
I tried renaming this field in the input file – and this didn’t work. So I removed the non-numeric field completely from the input file – and the calculator did work.
I believe the calculator somehow gets choked if there is a text array in a file. I am attaching the CSV file that I am trying to work with. The formula I am trying to apply to this is: iHat* 'FLOFx' + jHat * 'FLOFz'+ kHat * 0.
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
Attached Filescsv file icon TOUGH2_0000.csv [^] (322,591 bytes) 2012-02-28 15:00
-  Notes
(0038150)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
- Issue History
2012-02-28 15:00 Ann Moulding New Issue
2012-02-28 15:00 Ann Moulding File Added: TOUGH2_0000.csv
2016-08-12 09:59 Kitware Robot Note Added: 0038150
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
Powered by Mantis Bugtracker
