0012939 | ParaView | (No Category) | public | 2012-02-14 16:02 | 2012-07-18 19:05 | ||||
Target Version | Fixed in Version | 3.14 | |||||||
Summary | 0012939: Allow parallel test runs to speed up ParaView dashboards | ||||||||
Description | Allow parallel test runs to speed up ParaView dashboards. | ||||||||
Project | Kitware | ||||||||
Topic Name | 12939_enable_parallel_testing | ||||||||
Type | feature | ||||||||
(0028264) Utkarsh Ayachit (administrator) 2012-02-14 16:04 |
ctest -j N now supported for ParaView GUI/Client server tests. |
(0028265) Utkarsh Ayachit (administrator) 2012-02-14 16:04 |
commit 4d2a4bb5292687a37f9778becc8789aa52ec5576 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Feb 14 11:02:11 2012 -0500 Enable parallel tests. Removed logic that allowed code to disable running tests in parallel. Now all tests can run in parallel, if needed. commit 490133ed43f0d0ef83a4ee5ecae3e30ab344ec5f Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 13 23:58:11 2012 -0500 vtkSMTestDriver supports using random ports. vtkSMTestDriver now supports using random port numbers for client-server tests. This can be turned off by CMake variable PV_TEST_USE_RANDOM_PORTS (ON by default). vtkSMTestDriver parses output generated by server processes to tell the client the server-url to connect to. This is not yet supported for reverse-connection tests. Change-Id: I67a5743fea5b267d4c3ede8ef46ba5cc86a1b296 commit 8d82fd04cb729ac52f4ac0fa5bf612b355f0b25c Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 13 16:44:07 2012 -0500 Allow port 0 to be specified for waiting processes. When port 0 is specified, the process will pick a server port and print a status message on the stdout indicating the chosen port number. commit 5c71e306549ad398c14f23759eaa86cf720e7ab8 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 13 16:32:39 2012 -0500 Fixed handling of render-server URL. We had conflicting documentation!!! The doc said that the render server is separated by a "/" while the code looks for "//". Updating the regular expressions so that both cases are handled. Now cdsrs://miranda:11111/miranda:22221 as well as cdsrs://miranda:11111//miranda:22221 are valid URLs. commit be55fef7e41694820fd39caa0a5fb60bf36b18d8 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 13 15:58:10 2012 -0500 Removed pqTestingServers.pvsc. We'll leverage the -url option for cleaner testing support rather than using a configured file. Also fixed ServerConnectDialog test to since testing-servers were removed from the list resulting in change in the "click" locations. commit 2d5f554352e892d7499a9ba4894cbdc356de060d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 13 15:40:26 2012 -0500 Use real hostname instead of "localhost" by default. Instead of using "localhost" as the default server/client host name, the code now uses hostname. Consequently, one can now simply copy the URL printed out the server and paste it as the -url argument to the client to connect to it (so long as the client can connect to the server node). |
(0028288) Utkarsh Ayachit (administrator) 2012-02-17 12:22 |
Merged into git-master, if applicable. |
(0028801) Alan Scott (manager) 2012-07-18 19:05 |
Since dashboards are working, I am marking this closed. |
2012-02-14 16:02 | Utkarsh Ayachit | New Issue | |
2012-02-14 16:02 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-02-14 16:04 | Utkarsh Ayachit | Topic Name | => 12939_enable_parallel_testing |
2012-02-14 16:04 | Utkarsh Ayachit | Note Added: 0028264 | |
2012-02-14 16:04 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-02-14 16:04 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-02-14 16:04 | Utkarsh Ayachit | Resolution | open => fixed |
2012-02-14 16:04 | Utkarsh Ayachit | Note Added: 0028265 | |
2012-02-17 12:22 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-02-17 12:22 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-02-17 12:22 | Utkarsh Ayachit | Note Added: 0028288 | |
2012-02-20 10:28 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
2012-07-18 19:05 | Alan Scott | Note Added: 0028801 | |
2012-07-18 19:05 | Alan Scott | Status | customer review => closed |
