0012938 | ParaView | (No Category) | public | 2012-02-14 16:00 | 2012-02-20 10:28 | ||||
Target Version | Fixed in Version | 3.14 | |||||||
Summary | 0012938: Launching reverse connection jobs is not working without errors | ||||||||
Description | Refer to discussion thread: http://public.kitware.com/pipermail/paraview-developers/2012-February/001320.html [^] | ||||||||
Project | Sandia | ||||||||
Topic Name | 12938_fix_server_connection_issues | ||||||||
(0028263) Utkarsh Ayachit (administrator) 2012-02-14 16:02 |
commit b850454c42a0eb694ba42b6e4dc2daee25dfd83a Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 13 15:22:12 2012 -0500 Added support for -url (--server-url) command line option. ParaView client can now be launched using -url command line option to specify the server host and port to connect to (similar to ParView 2.*). commit f6f8f1fb7e0bc5a788dc62214629cb45d9e3f5ea Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 13 14:50:24 2012 -0500 Update status message printed by server executables. Even in reverse connection mode, the message said "Waiting for client" which was misleading. Fixed that. commit aadc75f97c830cfd1a5e7ebf90ee35125e8855e8 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Feb 11 20:10:19 2012 -0500 Fixed errors reported when using command startup for reverse connect. The problem was due to the fact that the client launched the server process before opening the socket to accept the server connect request. This caused in error messages from the server, more often than not. Although the server would eventually connnect, it was quite misleading. Fixed that. Now pqServerLauncher opens up the port before launching the server in reverse connect mode. commit 18fe3e3d8c2d9ff43621f504b36fcb183cf9616f Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Feb 11 18:58:44 2012 -0500 Fix bug in changing flag. There were cases when WaitingForConnection was left as true erroneously. Fixed that. commit b6e42902e53589ac08cba6116627922bb16f0697 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Feb 10 23:04:03 2012 -0500 Fixes server-connection issues on windows. * Added missing PV_CLIENT_HOST variable. * Fixed missing environment. * Ensuring that messages from process are shown in the output-window. * Handle case where script quits after server launch. Change-Id: I6c20e178bf6b45c30d105a5977d65c88e9762cd3 |
(0028287) Utkarsh Ayachit (administrator) 2012-02-17 12:22 |
Merged into git-master, if applicable. |
(0028297) Alan Scott (manager) 2012-02-17 23:31 |
I previously tested this remote server (command line connection as well as GUI connection), Linux, master. Another tester (John B.) also tested it. |
2012-02-14 16:00 | Utkarsh Ayachit | New Issue | |
2012-02-14 16:02 | Utkarsh Ayachit | Topic Name | => 12938_fix_server_connection_issues |
2012-02-14 16:02 | Utkarsh Ayachit | Note Added: 0028263 | |
2012-02-14 16:02 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-02-14 16:02 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-02-14 16:02 | Utkarsh Ayachit | Resolution | open => fixed |
2012-02-14 16:02 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-02-17 12:22 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-02-17 12:22 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-02-17 12:22 | Utkarsh Ayachit | Note Added: 0028287 | |
2012-02-17 23:31 | Alan Scott | Note Added: 0028297 | |
2012-02-17 23:31 | Alan Scott | Status | customer review => closed |
2012-02-20 10:28 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
