0012932 | ParaView | (No Category) | public | 2012-02-13 15:08 | 2012-04-12 20:47 | ||||
Reporter | Marcus D. Hanwell | ||||||||
Product Version | 3.14 | ||||||||
Target Version | Fixed in Version | 3.14 | |||||||
Summary | 0012932: Problems with charts and interaction - mouse offset | ||||||||
Description | I have reproduced this on current master, as well as the 3.14.0 RC2 build for 64 bit Linux. This applies to all of the chart types (line, bar, parallel coordinates, plot matrix). Create a sphere, filters->plot data. The split window that opens will suffer from a mouse offset (quite large). This is easily observed by right clicking and dragging to see a selection box. If you maximize the display the offset goes away, as it does when you reduce it back to the normal size. | ||||||||
Project | TBD | ||||||||
Topic Name | 12932_fix_chart_view_size_issues | ||||||||
Relationships | ||||||
(0028272) Utkarsh Ayachit (administrator) 2012-02-16 14:35 |
commit 4a8c4116b6e77e9354b356817d216af0920e6f47 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Feb 16 14:32:52 2012 -0500 BUG 0012932 and BUG 0012930. Fixes size issues with plots. The bug was that the size and position properties for plots were getting reset to default during initialization after the pqQVTKWidget had already updated them to correct values during resize() event handling (when the widget gets placed into the layout). |
(0028282) Utkarsh Ayachit (administrator) 2012-02-17 12:22 |
Merged into git-master, if applicable. |
(0028469) Alan Scott (manager) 2012-04-12 20:47 |
Tested local server, Linux, 3.14.1 |
2012-02-13 15:08 | Marcus D. Hanwell | New Issue | |
2012-02-13 15:08 | Marcus D. Hanwell | Assigned To | => Utkarsh Ayachit |
2012-02-16 14:35 | Utkarsh Ayachit | Topic Name | => 12932_fix_chart_view_size_issues |
2012-02-16 14:35 | Utkarsh Ayachit | Note Added: 0028272 | |
2012-02-16 14:35 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-02-16 14:35 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-02-16 14:35 | Utkarsh Ayachit | Resolution | open => fixed |
2012-02-16 14:35 | Utkarsh Ayachit | Relationship added | related to 0012930 |
2012-02-17 12:22 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-02-17 12:22 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-02-17 12:22 | Utkarsh Ayachit | Note Added: 0028282 | |
2012-02-20 10:28 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
2012-04-12 20:47 | Alan Scott | Note Added: 0028469 | |
2012-04-12 20:47 | Alan Scott | Status | customer review => closed |
