0012909 | ParaView | (No Category) | public | 2012-02-03 16:31 | 2012-04-12 20:05 | ||||
Reporter | Greg Weirs | ||||||||
Product Version | 3.12 | ||||||||
Target Version | Fixed in Version | 3.14 | |||||||
Summary | 0012909: Prism View: View controls are unresponsive after enabling and disabling log scaling | ||||||||
Description | In the prism view, by default the axes are rescaled so that the aspect ratio of the surface plot is 1:1:1. There is a special set of view controls that allow the user to control this rescaling. The user can specify the bounds for each axis that should be rescaled to length 1 in the view. (These values are independent of the bounds that specify what is displayed.) The bug is that when log scaling is enabled, then disabled, the bounds in the prism view control seem to be ignored. | ||||||||
Project | Sandia | ||||||||
Topic Name | 12780_prism_improvements | ||||||||
(0028076) Utkarsh Ayachit (administrator) 2012-02-07 14:52 |
Looks like this works now as far as I could tell. Please verify. commit b878e4c4f0d7e6138e8664adfe7a2969413e0aed Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Feb 7 14:37:41 2012 -0500 BUG 12909. Fixed view scaling issue. I believe the problem was due to the fact that the dialog was reused and hence it's state was incorrect when log-scaling was changed. Fixed by simply recreating the dialog each time. |
(0028095) Utkarsh Ayachit (administrator) 2012-02-08 10:41 |
merged into master, if applicable. |
(0028462) Alan Scott (manager) 2012-04-12 20:05 |
Tested local server, Linux, 3.14.1 |
2012-02-03 16:31 | Greg Weirs | New Issue | |
2012-02-06 14:57 | Alan Scott | Status | backlog => todo |
2012-02-06 15:10 | Alan Scott | Project | TBD => Sandia |
2012-02-07 14:52 | Utkarsh Ayachit | Topic Name | => 12780_prism_improvements |
2012-02-07 14:52 | Utkarsh Ayachit | Note Added: 0028076 | |
2012-02-07 14:52 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-02-07 14:52 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-02-07 14:52 | Utkarsh Ayachit | Resolution | open => fixed |
2012-02-07 14:52 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-02-08 10:41 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-02-08 10:41 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-02-08 10:41 | Utkarsh Ayachit | Note Added: 0028095 | |
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
2012-04-12 20:05 | Alan Scott | Note Added: 0028462 | |
2012-04-12 20:05 | Alan Scott | Status | customer review => closed |
