0012867 | ParaView | (No Category) | public | 2012-01-21 05:07 | 2016-08-12 09:59 | ||||
Reporter | Takuya OSHIMA | ||||||||
Summary | 0012867: Coprocessing export state from layout #2 crashes ParaView | ||||||||
Description | Git-master as of today, OS X 10.6.8, Qt 4.7.2. 1. Start PV. 2. Load Coprocessing plugin. 3. Click the + button at the top of the graphics view to open Layout #2. 4. Sources->Wavelet. Apply. 5. Coprocessing->Export State. Then PV crashes leaving the following message on the terminal. ERROR: In /Volumes/RAID0data/paraview/ParaView/VTK/Filtering/vtkDemandDrivenPipeline.cxx, line 727 vtkCompositeDataPipeline (0x123aa5bb0): Input port 0 of algorithm vtkPNGWriter(0x123aa5050) has 0 connections but is not optional. ERROR: In /Volumes/RAID0data/paraview/ParaView/VTK/IO/vtkPNGWriter.cxx, line 54 vtkPNGWriter (0x123aa5050): Write:Please specify an input! Segmentation fault | ||||||||
Project | Kitware | ||||||||
(0038125) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-01-21 05:07 | Takuya OSHIMA | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038125 | |
