0012861 | ParaView | (No Category) | public | 2012-01-17 15:04 | 2016-08-12 09:59 | ||||
Reporter | Hal Canary | ||||||||
Product Version | 3.12 | ||||||||
Summary | 0012861: Unable to ask for user input from within ParaView Python macro | ||||||||
Description | In ParaView 3.8.1, it was possible to write a Python macro that asked the user for input with a dialog window. This was done with the following simple code: import PyQt4.QtGui (ret, ok) = PyQt4.QtGui.QInputDialog.getInt( PyQt4.QtGui.QWidget(), 'T', 'L') if not ok: raise Exception('input error') print ret Starting with 3.10 and continuing with 3.12.0, this will fail. If there is a good reason to disallow "import PyQt4.QtGui" in ParaView, I understand, but can we implement equivalent functionality to these four static functions PyQt4.QtGui.QInputDialog.getInt() PyQt4.QtGui.QInputDialog.getItem() PyQt4.QtGui.QInputDialog.getDouble() PyQt4.QtGui.QInputDialog.getText() from within a ParaView Python macro? | ||||||||
Project | TBD | ||||||||
Type | usability | ||||||||
Attached Files | python-gui-test.py [^] (1,691 bytes) 2012-01-17 15:04 | ||||||||
(0038123) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-01-17 15:04 | Hal Canary | New Issue | |
2012-01-17 15:04 | Hal Canary | File Added: python-gui-test.py | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038123 | |
