0012725ParaView(No Category)public2011-11-13 13:122012-02-08 17:24
ReporterPat Marion
Assigned ToSebastien Jourdain
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version3.14
Summary0012725: Regression in paraview.simple python module
DescriptionThe CreateObject functions are not correctly added to paraview.simple
In paraview 3.10:
  >>> paraview.simple.Sphere
  <function CreateObject at 0x128bcade8>
In parview 3.12:
  Traceback (most recent call last):
    File "<console>", line 1, in <module>
  AttributeError: 'module' object has no attribute 'Sphere'
This is a regression that I tracked to commit 9f1626b. The commit message says:
"Also fixed servermanager.py to create module functions only after a server connection was made."
Previously, this statement was executed by simple.py when it was imported:
  _add_functions(globals())
But commit 9f1626b moves that statement into the Connect() function, which is never called by the GUI, it is only called by pvpython. A 'hack' was added in commit a2e764e which adds c++ code to explicitly execute the statement after paraview.simple is imported, but this is wrong, because the globals() passed to _add_functions() is the globals of the main context, not the globals of paraview.simple.
Attached is a patch that fixes the issue, but I don't clearly understand why commit 9f1626b needed to make the change that it did in the first place. It seems that my attached patch is roughly equivalent to reverting the change.
TagsNo tags attached.
ProjectTBD
Topic Name12725-regression-python-module
Typeincorrect functionality
Attached Filespatch file icon paraview_simple_fix.patch [^] (1,130 bytes) 2011-11-13 13:12 [Show Content]
 Relationships
  Notes
(0027689)
Pat Marion (reporter)
2011-11-13 13:14
Utkarsh, could you take a look at this bug sometime? Maybe you could ask Sebastien why he did what he did :)
(0027691)
Sebastien Jourdain (manager)
2011-11-15 09:56
The reason why I did those changes, it is because the _add_function needed to happen after Connect and not at the import time as the Proxy definition come from the server now which was not the case previously. So your patch seems reasonable in the sense that with the GUI, we are already connected...
(0027692)
2011-11-15 11:31
So what happens when the GUI disconnects from the builtin server and connects to a new remote server? Is it possible that the remote server has additional proxy definitions that will not make it into paraview.simple? What if the remote server has fewer proxy definitions? Is the only way to change the number of proxy definitions when there is a plugin loaded?
(0027693)
2011-11-15 12:06
When you connect or disconnect from a server and you have a python shell open, that shell get totally reinitialized, therefore the simple get the proper latest proxy definitions. The only runtime update available so far was with plugin loading.
Although, I'm working in bringing support for multi-server connection, which exactly means that based on which server is active, the proxy definition available inside simple could be different. For that, I had to add a _remove_function method add clean up some of the previous code. That code already works great inside pvpython but I need to properly integrate it when python is used inside ParaView.
(0027717)
2011-11-18 14:54
merged to master.
(0028114)
2012-02-08 17:24
Closing bugs sitting in "customer review" for a long time.
 Issue History
2011-11-13 13:12 Pat Marion New Issue
2011-11-13 13:12 Pat Marion File Added: paraview_simple_fix.patch
2011-11-13 13:14 Pat Marion Note Added: 0027689
2011-11-15 09:42 Sebastien Jourdain Assigned To => Sebastiennn Jourdain
2011-11-15 09:42 Sebastien Jourdain Status backlog => todo
2011-11-15 09:42 Sebastien Jourdain Status todo => active development
2011-11-15 09:56 Sebastien Jourdain Note Added: 0027691
2011-11-15 11:12 Sebastien Jourdain Status active development => gatekeeper review
2011-11-15 11:12 Sebastien Jourdain Resolution open => fixed
2011-11-15 11:13 Sebastien Jourdain Topic Name => 12725-regression-python-module
2011-11-15 11:31 Pat Marion Note Added: 0027692
2011-11-15 12:06 Sebastien Jourdain Note Added: 0027693
2011-11-18 14:53 Utkarsh Ayachit Fixed in Version => git-master
2011-11-18 14:54 Utkarsh Ayachit Status gatekeeper review => customer review
2011-11-18 14:54 Utkarsh Ayachit Note Added: 0027717
2012-02-08 17:21 Utkarsh Ayachit Fixed in Version git-master => 3.14
2012-02-08 17:24 Utkarsh Ayachit Status customer review => closed
2012-02-08 17:24 Utkarsh Ayachit Note Added: 0028114
