0012704 | ParaView | (No Category) | public | 2011-11-03 11:12 | 2012-02-08 17:27 | ||||
Reporter | Bob O'Bara | ||||||||
Assigned To | Bob O'Bara | ||||||||
Target Version | Fixed in Version | 3.14 | |||||||
Summary | 0012704: vtkSmartVolumeMapper Does not process interactive vs still frame rate properly | ||||||||
Description | When trying to use the mapper, it doesn't switch properly from interactive to still frame rates. This is clearly demonstrated when using Texture Map/Ray Cast mode - it never does a Ray Cast Render | ||||||||
Project | AMR Streaming | ||||||||
Topic Name | fixSmartVolumeMapper | ||||||||
(0027655) Bob O'Bara (developer) 2011-11-03 11:33 |
Added fix to next branch |
(0028214) Utkarsh Ayachit (administrator) 2012-02-08 17:27 |
Closing bugs sitting in "customer review" for a long time. |
2011-11-03 11:12 | Bob O'Bara | New Issue | |
2011-11-03 11:12 | Bob O'Bara | Assigned To | => Bob O'Bara |
2011-11-03 11:12 | Bob O'Bara | Status | backlog => todo |
2011-11-03 11:12 | Bob O'Bara | Status | todo => active development |
2011-11-03 11:33 | Bob O'Bara | Topic Name | => fixSmartVolumeMapper |
2011-11-03 11:33 | Bob O'Bara | Note Added: 0027655 | |
2011-11-03 11:33 | Bob O'Bara | Status | active development => gatekeeper review |
2011-11-03 11:33 | Bob O'Bara | Fixed in Version | => git-next |
2011-11-03 11:33 | Bob O'Bara | Resolution | open => fixed |
2011-11-03 16:01 | Bob O'Bara | Summary | vtkSmartVolumeMapper Does not process interactive vs still frame rate properlyWhen trying to use the mapper, it does switch prop => vtkSmartVolumeMapper Does not process interactive vs still frame rate properly |
2011-11-03 16:01 | Bob O'Bara | Description Updated | |
2011-11-11 17:01 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-11-11 17:01 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
2012-02-08 17:27 | Utkarsh Ayachit | Status | customer review => closed |
2012-02-08 17:27 | Utkarsh Ayachit | Note Added: 0028214 |
