0012691VTK(No Category)public2011-10-31 14:312013-07-22 17:16
Reportertd123
Assigned ToDave DeMarle
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version5.8.0
Target VersionFixed in Version6.0.0
Summary0012691: vtk incompatible with ffmpeg 0.8 api
DescriptionI get errors when trying to build vtk against the latest ffmpeg on archlinux.
Debian seems to have the relevant patch and when I applied it and rebuilt, it fixed the error:
http://patch-tracker.debian.org/patch/series/view/vtk/5.8.0-1/debian-changes-5.6.1-6.1 [^]
The following is the full error message:
[ 47%] Building CXX object IO/CMakeFiles/vtkIO.dir/vtkFFMPEGWriter.cxx.o
/build/src/VTK/IO/vtkFFMPEGWriter.cxx: In member function ‘int vtkFFMPEGWriterInternal::Start()’:
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:126:56: error: ‘guess_format’ was not declared in this scope
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:143:20: warning: ‘AVStream* av_new_stream(AVFormatContext*, int)’ is deprecated (declared at /usr/include/libavformat/avformat.h:1528) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:143:58: warning: ‘AVStream* av_new_stream(AVFormatContext*, int)’ is deprecated (declared at /usr/include/libavformat/avformat.h:1528) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:153:19: error: ‘CODEC_TYPE_VIDEO’ was not declared in this scope
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:196:7: warning: ‘int av_set_parameters(AVFormatContext*, AVFormatParameters*)’ is deprecated (declared at /usr/include/libavformat/avformat.h:1611) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:196:52: warning: ‘int av_set_parameters(AVFormatContext*, AVFormatParameters*)’ is deprecated (declared at /usr/include/libavformat/avformat.h:1611) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:209:7: warning: ‘int avcodec_open(AVCodecContext*, AVCodec*)’ is deprecated (declared at /usr/include/libavcodec/avcodec.h:3905) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:209:28: warning: ‘int avcodec_open(AVCodecContext*, AVCodec*)’ is deprecated (declared at /usr/include/libavcodec/avcodec.h:3905) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:262:7: warning: ‘int url_fopen(AVIOContext**, const char*, int)’ is deprecated (declared at /usr/include/libavformat/avio.h:279) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:262:88: warning: ‘int url_fopen(AVIOContext**, const char*, int)’ is deprecated (declared at /usr/include/libavformat/avio.h:279) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:269:3: warning: ‘int av_write_header(AVFormatContext*)’ is deprecated (declared at /usr/include/libavformat/avformat.h:1669) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:269:40: warning: ‘int av_write_header(AVFormatContext*)’ is deprecated (declared at /usr/include/libavformat/avformat.h:1669) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx: In member function ‘int vtkFFMPEGWriterInternal::Write(vtkImageData*)’:
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:346:20: error: ‘PKT_FLAG_KEY’ was not declared in this scope
/build/src/VTK/IO/vtkFFMPEGWriter.cxx: In member function ‘void vtkFFMPEGWriterInternal::End()’:
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:394:7: warning: ‘int url_fclose(AVIOContext*)’ is deprecated (declared at /usr/include/libavformat/avio.h:280) [-Wdeprecated-declarations]
/build/src/VTK/IO/vtkFFMPEGWriter.cxx:394:43: warning: ‘int url_fclose(AVIOContext*)’ is deprecated (declared at /usr/include/libavformat/avio.h:280) [-Wdeprecated-declarations]
make[2]: *** [IO/CMakeFiles/vtkIO.dir/vtkFFMPEGWriter.cxx.o] Error 1
make[1]: *** [IO/CMakeFiles/vtkIO.dir/all] Error 2
make: *** [all] Error 2
==> ERROR: A failure occurred in build().
    Aborting...
TagsNo tags attached.
ProjectTBD
Typeincorrect functionality
 Relationships
  Notes
(0031181)
Dave DeMarle (administrator)
2013-07-22 17:16
Should be fixed since:
commit d48033e127b208228b46f820d454c5eca1c719e1
Author: Luca Barbato <lu_zero@gentoo.org>
Date: Tue Jun 4 19:47:03 2013 -0400
 Issue History
2011-10-31 14:31 td123 New Issue
2013-07-22 17:15 Dave DeMarle Assigned To => Dave DeMarle
2013-07-22 17:15 Dave DeMarle Status backlog => todo
2013-07-22 17:15 Dave DeMarle Status todo => active development
2013-07-22 17:16 Dave DeMarle Note Added: 0031181
2013-07-22 17:16 Dave DeMarle Status active development => closed
2013-07-22 17:16 Dave DeMarle Resolution open => fixed
2013-07-22 17:16 Dave DeMarle Fixed in Version => 6.0.0
