0012639 | ParaView | (No Category) | public | 2011-10-10 17:04 | 2016-08-12 09:58 | ||||
Reporter | Robert Maynard | ||||||||
Product Version | 3.12 | ||||||||
Summary | 0012639: Configuration with MESA enabled is a nightmare | ||||||||
Description | Currently you have to set the following flags to properly build with OSMesa. VTK_OPENGL_HAS_OSMESA is enabled. OPENGL_INCLUDE_DIR set to OSMesa library OPENGL_gl_LIBRARY is empty if you want offscreen rendering OPENGL_glu_LIBRARY set the to library built by OSMesa VTK_USE_X is turned off Ontop of that VTK_USE_X doesn't properly clear itself once it is toggled on, so if that happens you need to blow away the entire build directory. We really should have a single non advanced option which is ENABLE_OSMESA which does everything for the end user. | ||||||||
Project | Sandia | ||||||||
(0027561) Alan Scott (manager) 2011-10-10 17:08 |
Furthermore, if Mesa is turned on, if a user turns on an incompatible switch, at least a warning message should be printed out. |
(0027562) Alan Scott (manager) 2011-10-10 17:11 |
OK, I just checked, and VTK_USE_X is turned on by default, and must explicitly be turned off. This is nuts. |
(0038081) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-10-10 17:04 | Robert Maynard | New Issue | |
2011-10-10 17:08 | Alan Scott | Note Added: 0027561 | |
2011-10-10 17:11 | Alan Scott | Note Added: 0027562 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038081 | |
