0012627 | ParaView | (No Category) | public | 2011-10-04 05:44 | 2016-08-12 09:58 | ||||
Reporter | Peter Potrowl | ||||||||
Summary | 0012627: Add a 'refresh' function | ||||||||
Description | For my research work, I often need to display the result of a simulation while the simulation is running. To do this, I open a series of .vtu files. The content is displayed in Paraview. A few minutes later, I need to update the view in Paraview. As far as I know, the only way to do that is to: * delete the series in "Pipeline browser" (click in "Pipeline browser" plus press [del]) * reopen the series manually (click "Open" plus click on the file) * click "Apply" in "Properties" * click "Display" * select the wanted parameter in "Color by" * click "Last frame" to display the current status of the simulation So, that's about eight click/press actions that I need to do every few minutes when using ParaView. I think this could be done much more efficiently by adding a "Refresh" function that would reopen the open .vtu series, keeping the same parameters as the current ones, and display the last frame of the animation. I saw there is a "Macros" menu, empty, and I couldn't find a way to create a macro for this. I couldn't find a plugin to do that and searching the wiki didn't help... I think Paraview worths a builtin function for this... | ||||||||
Project | ParaViS | ||||||||
Type | feature | ||||||||
(0035192) Alan Scott (manager) 2015-09-09 21:27 |
Lets add a refresh button to the vtk reader. |
(0038077) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-10-04 05:44 | Peter Potrowl | New Issue | |
2015-09-09 21:27 | Alan Scott | Note Added: 0035192 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038077 | |
