0012608 | ParaView | (No Category) | public | 2011-09-21 09:36 | 2015-01-11 08:36 | ||||
Reporter | Robert Maynard | ||||||||
Target Version | 3.12 | Fixed in Version | 3.14 | ||||||
Summary | 0012608: Prisms Sesame Conversion xml needs to be installed. | ||||||||
Description | N/T | ||||||||
Project | Sandia | ||||||||
Topic Name | 12608_default_sesame_file | ||||||||
(0027510) Robert Maynard (developer) 2011-09-21 09:38 |
The SESAMEConversion.xml is installed in the bin directory. |
(0027517) David Partyka (developer) 2011-09-23 14:25 |
Merged into master |
(0027518) David Partyka (developer) 2011-09-23 14:25 |
(0027751) Greg Weirs (developer) 2011-12-01 12:05 |
It seems for the mac binary the SESAMEConversions.xml does not get installed. Also on sandia's lan builds, it is not clear it gets installed. |
(0028064) Utkarsh Ayachit (administrator) 2012-02-06 16:56 |
commit b50448b2f57a6f816ce2a494b6d233792495563e Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 6 16:54:31 2012 -0500 BUG 0012608. Default SESAME conversion tables are now compiled in. To make it easier for user to use the default conversion table, these are now compiled in. The panel by default loads these and user needs to load a file only to override the default. |
(0028094) Utkarsh Ayachit (administrator) 2012-02-08 10:41 |
merged into master, if applicable. |
(0028305) Alan Scott (manager) 2012-02-18 00:13 |
This is good. Tested by greg. |
2011-09-21 09:36 | Robert Maynard | New Issue | |
2011-09-21 09:36 | Robert Maynard | Assigned To | => Robert Maynard |
2011-09-21 09:38 | Robert Maynard | Topic Name | => 12608-install-sesame-file |
2011-09-21 09:38 | Robert Maynard | Note Added: 0027510 | |
2011-09-21 09:38 | Robert Maynard | Status | backlog => gatekeeper review |
2011-09-21 09:38 | Robert Maynard | Fixed in Version | => git-next |
2011-09-21 09:38 | Robert Maynard | Resolution | open => fixed |
2011-09-23 14:25 | David Partyka | Note Added: 0027517 | |
2011-09-23 14:25 | David Partyka | Note Added: 0027518 | |
2011-09-23 14:25 | David Partyka | Status | gatekeeper review => customer review |
2011-09-23 14:40 | David Partyka | Target Version | => 3.12 |
2011-11-11 17:08 | Utkarsh Ayachit | Fixed in Version | git-next => 3.12 |
2011-12-01 12:05 | Greg Weirs | Note Added: 0027751 | |
2012-02-06 16:53 | Utkarsh Ayachit | Assigned To | Robert Maynard => Utkarsh Ayachit |
2012-02-06 16:53 | Utkarsh Ayachit | Status | customer review => todo |
2012-02-06 16:56 | Utkarsh Ayachit | Topic Name | 12608-install-sesame-file => 12608_default_sesame_file |
2012-02-06 16:56 | Utkarsh Ayachit | Note Added: 0028064 | |
2012-02-06 16:56 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-02-06 16:56 | Utkarsh Ayachit | Fixed in Version | 3.12 => git-next |
2012-02-08 10:41 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-02-08 10:41 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-02-08 10:41 | Utkarsh Ayachit | Note Added: 0028094 | |
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
2012-02-18 00:13 | Alan Scott | Note Added: 0028305 | |
2012-02-18 00:13 | Alan Scott | Status | customer review => closed |
2015-01-11 08:34 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master b9f1c03c |
2015-01-11 08:34 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master b50448b2 |
2015-01-11 08:36 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master d3d84595 |
