0012561 | ParaView | (No Category) | public | 2011-08-30 14:34 | 2012-02-08 17:24 | ||||
Reporter | Andy Bauer | ||||||||
Assigned To | Andy Bauer | ||||||||
Target Version | Fixed in Version | 3.14 | |||||||
Summary | 0012561: add extra functionality to coprocessing tools | ||||||||
Description | Add the following functionality to the coprocessing tools: 1) Specify that the simulation is at the last time step and that the coprocessing scripts should execute 2) Add an option for to rescale the data range to fit data bounds when a screenshot is exported. | ||||||||
Project | TBD | ||||||||
Topic Name | 12561-coprocessing-export-screenshots | ||||||||
Type | feature | ||||||||
(0027444) Andy Bauer (developer) 2011-09-01 21:41 |
Emailed Nathan Fabian and he liked these changes too. The API change won't affect them. |
(0027457) Andy Bauer (developer) 2011-09-06 15:48 |
Merge error caused bug to be introduced. |
(0027458) Andy Bauer (developer) 2011-09-06 15:49 |
Fixed. This needs to go into the 3.12 release as well since this will cause all coprocessing scripts that are generated with the plugin to fail. |
(0027466) Utkarsh Ayachit (administrator) 2011-09-09 14:14 |
merged into git-master. |
(0027931) Andy Bauer (developer) 2012-01-11 09:05 |
Adding similar functionality: 1) image outputs now can have different output frequencies and filenames 2) image outputs can be fit to screen 3) can rescale to data range but this is done for all views/image outputs 4) input is automatically called "input" in the exporter wizard 5) can double click on sources to add and remove sources used in the script |
(0027936) Utkarsh Ayachit (administrator) 2012-01-13 14:07 |
merged into master. |
(0027943) Andy Bauer (developer) 2012-01-16 10:46 |
Found a bug when the user checks to rescale data range in the export wizard but some representations don't use a lookup table. |
(0027951) Andy Bauer (developer) 2012-01-19 23:27 |
The fix was done on the same topic branch. |
(0027954) Utkarsh Ayachit (administrator) 2012-01-20 14:20 |
merged in master (whenever applicable) |
(0028125) Utkarsh Ayachit (administrator) 2012-02-08 17:24 |
Closing bugs sitting in "customer review" for a long time. |
2011-08-30 14:34 | Andy Bauer | New Issue | |
2011-08-30 14:34 | Andy Bauer | Assigned To | => Andy Bauer |
2011-09-01 11:49 | Andy Bauer | Status | backlog => todo |
2011-09-01 11:50 | Andy Bauer | Status | todo => active development |
2011-09-01 21:41 | Andy Bauer | Topic Name | => 12561-new-coprocessing-features |
2011-09-01 21:41 | Andy Bauer | Note Added: 0027444 | |
2011-09-01 21:41 | Andy Bauer | Status | active development => gatekeeper review |
2011-09-01 21:41 | Andy Bauer | Fixed in Version | => git-master |
2011-09-01 21:41 | Andy Bauer | Resolution | open => fixed |
2011-09-02 13:46 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-09-06 15:48 | Andy Bauer | Note Added: 0027457 | |
2011-09-06 15:48 | Andy Bauer | Status | customer review => todo |
2011-09-06 15:48 | Andy Bauer | Status | todo => active development |
2011-09-06 15:49 | Andy Bauer | Note Added: 0027458 | |
2011-09-06 15:49 | Andy Bauer | Status | active development => gatekeeper review |
2011-09-07 09:53 | Utkarsh Ayachit | Fixed in Version | git-master => git-next |
2011-09-09 14:13 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2011-09-09 14:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-09-09 14:14 | Utkarsh Ayachit | Note Added: 0027466 | |
2011-11-11 17:03 | Utkarsh Ayachit | Fixed in Version | git-master => 3.12 |
2012-01-03 13:12 | Andy Bauer | Status | customer review => closed |
2012-01-11 09:05 | Andy Bauer | Note Added: 0027931 | |
2012-01-11 09:05 | Andy Bauer | Status | closed => backlog |
2012-01-11 09:05 | Andy Bauer | Resolution | fixed => reopened |
2012-01-11 09:05 | Andy Bauer | Status | backlog => todo |
2012-01-11 09:05 | Andy Bauer | Status | todo => active development |
2012-01-11 09:06 | Andy Bauer | Topic Name | 12561-new-coprocessing-features => 12561-coprocessing-export-screenshots |
2012-01-11 09:06 | Andy Bauer | Status | active development => gatekeeper review |
2012-01-11 09:06 | Andy Bauer | Resolution | reopened => fixed |
2012-01-13 14:07 | Utkarsh Ayachit | Note Added: 0027936 | |
2012-01-13 14:07 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-01-13 14:07 | Utkarsh Ayachit | Fixed in Version | 3.12 => git-master |
2012-01-16 10:46 | Andy Bauer | Note Added: 0027943 | |
2012-01-16 10:46 | Andy Bauer | Status | customer review => todo |
2012-01-16 10:46 | Andy Bauer | Status | todo => active development |
2012-01-19 23:27 | Andy Bauer | Note Added: 0027951 | |
2012-01-19 23:27 | Andy Bauer | Status | active development => gatekeeper review |
2012-01-20 14:20 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-01-20 14:20 | Utkarsh Ayachit | Note Added: 0027954 | |
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
2012-02-08 17:24 | Utkarsh Ayachit | Status | customer review => closed |
2012-02-08 17:24 | Utkarsh Ayachit | Note Added: 0028125 |
