0000124VTK(No Category)public2003-08-03 11:592004-02-02 16:53
ReporterSystem Admin
Assigned ToSystem Admin
PriorityhighSeveritymajorReproducibilityalways
StatusclosedResolutionduplicate
PlatformOSOS Version
Product Version
Summary0000124: VTK_USE_ANSI_STDLIB should be set by default on some compilers
DescriptionCMake does try_compile, so it should check for iostream.h and iostream and only if they are both not available it should present the option.
Otherwise on Visual Studio .NET using nmake you get an error.
TagsNo tags attached.
Project
Type
-  Notes
There are no notes attached to this issue.
- Issue History
Powered by Mantis Bugtracker
