0012379 | ParaView | (No Category) | public | 2011-07-19 14:45 | 2011-07-22 14:15 | ||||
Reporter | Kyle Lutz | ||||||||
Assigned To | Kyle Lutz | ||||||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0012379: Add clean unstructured grid cell filter | ||||||||
Description | On Wed, Jun 29, 2011 at 4:50 PM, Randall Hand <randall.hand@gmail.com> wrote: >>> I'm working with an Xdmf dataset in ParaView 3.10.1 that has multiple >>> unstructured-grid blocks with overlap regions, however doens't seem to >>> actually have "ghost" cells. This means when I extract an isosurface, I >>> wind up with perfectly overlapping faces. >>> >>> I can use the Clean filter to eliminate coincident points, but but >>> coincident faces. As an example, if I use the "Select Cells Through" >>> option to select 2 triangles on an overlapping border, I get 4 points >>> (normal for 2 triangles) but 5 cells, with perfect overlap. The results >>> from an ASCII VTK File saved to disk: >>> >>> vtk output >>> ASCII >>> DATASET POLYDATA >>> POINTS 4 float >>> 1.37916 0.965356 0.21928 >>> 1.37129 0.964077 0.218481 >>> 1.37613 0.958331 0.219823 >>> 1.36947 0.958944 0.21948 >>> POLYGONS 5 20 >>> 3 0 1 2 >>> 3 2 1 3 >>> 3 0 1 2 >>> 3 2 1 3 >>> 3 2 1 3 >>> >>> Is there any filter in ParaView capable of fixing this? Or does it have >>> to be an arduously slow Python script to run in a Programmable Filter? | ||||||||
Project | TBD | ||||||||
Topic Name | add-clean-unstructured-grid-cell-filter | ||||||||
Type | feature | ||||||||
(0027016) Kyle Lutz (viewer) 2011-07-19 14:53 |
Merge topic 'add-clean-unstructured-grid-cell-filter' into next 6904ee7 Add vtkCleanUnstructuredGridCells filter |
(0027052) Utkarsh Ayachit (administrator) 2011-07-21 19:18 |
Scheduled for gatekeeper review on Jul 22, 2011 at 2 pm EDT. |
(0027063) Utkarsh Ayachit (administrator) 2011-07-22 14:13 |
Merged to git-master. |
2011-07-19 14:45 | Kyle Lutz | New Issue | |
2011-07-19 14:45 | Kyle Lutz | Assigned To | => Kyle Lutz |
2011-07-19 14:46 | Kyle Lutz | Status | backlog => todo |
2011-07-19 14:46 | Kyle Lutz | Status | todo => active development |
2011-07-19 14:53 | Kyle Lutz | Note Added: 0027016 | |
2011-07-19 14:53 | Kyle Lutz | Topic Name | => add-clean-unstructured-grid-cell-filter |
2011-07-19 14:53 | Kyle Lutz | Status | active development => gatekeeper review |
2011-07-19 14:53 | Kyle Lutz | Fixed in Version | => 3.12 |
2011-07-19 14:53 | Kyle Lutz | Resolution | open => fixed |
2011-07-21 19:18 | Utkarsh Ayachit | Note Added: 0027052 | |
2011-07-22 14:13 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-07-22 14:13 | Utkarsh Ayachit | Note Added: 0027063 | |
2011-07-22 14:15 | Utkarsh Ayachit | Status | customer review => closed |
