0012331 | VTK | (No Category) | public | 2011-07-03 21:44 | 2013-12-13 10:05 | ||||
Reporter | Peter Wood | ||||||||
Assigned To | Dave DeMarle | ||||||||
Target Version | Fixed in Version | 6.1.0 | |||||||
Summary | 0012331: Tolerance problem in 'vtkImplicitDataSet::EvaluateFunction': 'tol2' set as 0.0, which appears to be too tight | ||||||||
Description | Tolerance problem in 'vtkImplicitDataSet.cxx' in method 'EvaluateFunction' line 81, as follows """ // Find the cell that contains xyz and get it cell = this->DataSet->FindAndGetCell(x,NULL,-1,0.0,subId,pcoords,this->Weights); ^^^ """ Note 4th parameter '0.0'. This is 'tol2' in API, which is used in 'vtkPointSet.cxx' in method 'FindCellWalk' """ double dist2; if ( (cell->EvaluatePosition(x, closestPoint, subId, pcoords, dist2, weights) == 1) && (dist2 <= tol2) ) { return cellId; } """ The problem is that 'tol2' is 0.0, but often 'dist2' may be calculated to be approx 1e-032 to 1e-029, a very small number, but still greater than 0.0! (NB: I adapted vtkPointSet.cxx to report 'dist2') To fix this problem, when calling 'FindAndGetCell' in 'vtkImplicitDataSet' replace '0.0' with an appropriate small positive tolerance value, e.g. '1e-16'. This could be user-configurable? | ||||||||
Project | TBD | ||||||||
Attached Files | test_vtkImplicitDataSet_tol2_problem.py [^] (2,732 bytes) 2011-07-03 21:44 | ||||||||
(0026947) Peter Wood (reporter) 2011-07-03 22:43 |
One option may be to replace '0.0' with VTK_DBL_EPSILON ? |
(0030898) Jean-Christophe Fillion-Robin (manager) 2013-06-05 13:20 |
Does the problem still occur with VTK 5.10 ? VTK 6 ? Would be great if you could submit a patch using Gerrit. For more details see http://www.vtk.org/Wiki/VTK/Git/Develop [^] Thanks Jc |
(0031928) Dave DeMarle (administrator) 2013-12-13 10:05 |
http://review.source.kitware.com/#/t/3022/ [^] merged |
2011-07-03 21:44 | Peter Wood | New Issue | |
2011-07-03 21:44 | Peter Wood | File Added: test_vtkImplicitDataSet_tol2_problem.py | |
2011-07-03 22:43 | Peter Wood | Note Added: 0026947 | |
2013-06-05 13:20 | Jean-Christophe Fillion-Robin | Note Added: 0030898 | |
2013-12-13 10:05 | Dave DeMarle | Note Added: 0031928 | |
2013-12-13 10:05 | Dave DeMarle | Status | backlog => closed |
2013-12-13 10:05 | Dave DeMarle | Assigned To | => Dave DeMarle |
2013-12-13 10:05 | Dave DeMarle | Resolution | open => fixed |
2013-12-13 10:05 | Dave DeMarle | Fixed in Version | => 6.1.0 |
