0012311 | ParaView | (No Category) | public | 2011-06-23 18:13 | 2012-02-08 17:28 | ||||
Target Version | 3.12 | Fixed in Version | 3.12 | ||||||
Summary | 0012311: Add support to ParaView to determine version using "git describe" | ||||||||
Description | Add support to ParaView to determine version using "git describe" | ||||||||
Project | Kitware | ||||||||
Topic Name | 12311_change_version_policy | ||||||||
(0027195) Utkarsh Ayachit (administrator) 2011-08-02 09:03 |
Dave, can you start working on this soon? We should update the version number mechanics before the next release. |
(0027416) Utkarsh Ayachit (administrator) 2011-08-22 17:00 |
commit f744f457894ddc75a7bbf11a87d81beeb971b71d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Aug 22 16:54:37 2011 -0400 Fixed BUG 0012311. Changed ParaView version number policy. We now use "git describe" to determine the version for ParaView. Thus we no longer have to use minor/major version number trick for releases. "git describe" returns a string such as "v3.10.1-1701-g427f283". The version is then set as follows: Major: 3 Minor: 10 Patch: 1 Full : 3.10.1-1701-g427f283 If Full=="Major.Minor.Patch", then it's treated as a release. Release candidates can be tagged as "x.y.z-rcN" and the version will be set correctly. If git cannot determine the source version correctly, then "CMake/.paraview.version" file is searched for and we try to parse the version string from this file. It's a fatal error is both these approaches fail. |
(0027434) Utkarsh Ayachit (administrator) 2011-08-30 10:26 |
Not working when git is not found. |
(0027435) Utkarsh Ayachit (administrator) 2011-08-30 10:27 |
commit 53ca2aacdd00f8f91caaa543c6358b05edd2597a Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Aug 30 10:26:57 2011 -0400 Removed debugging code. commit 7156d760d68afdadcfcd61d91c20611a9fc430f4 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Aug 30 10:25:08 2011 -0400 Fixed case when git was not available. |
(0028244) Utkarsh Ayachit (administrator) 2012-02-08 17:28 |
Closing bugs sitting in "customer review" for a long time. |
2011-06-23 18:13 | Utkarsh Ayachit | New Issue | |
2011-06-23 18:13 | Utkarsh Ayachit | Assigned To | => David Partyka |
2011-06-23 18:15 | Utkarsh Ayachit | Status | backlog => todo |
2011-08-02 09:03 | Utkarsh Ayachit | Note Added: 0027195 | |
2011-08-02 09:03 | Utkarsh Ayachit | Priority | normal => high |
2011-08-02 09:03 | Utkarsh Ayachit | Target Version | => 3.12 |
2011-08-02 13:52 | David Partyka | Status | todo => active development |
2011-08-22 16:54 | Utkarsh Ayachit | Assigned To | David Partyka => Utkarsh Ayachit |
2011-08-22 17:00 | Utkarsh Ayachit | Topic Name | => 12311_change_version_policy |
2011-08-22 17:00 | Utkarsh Ayachit | Note Added: 0027416 | |
2011-08-22 17:00 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2011-08-22 17:00 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
2011-08-22 17:00 | Utkarsh Ayachit | Resolution | open => fixed |
2011-08-26 15:57 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-08-30 10:26 | Utkarsh Ayachit | Note Added: 0027434 | |
2011-08-30 10:26 | Utkarsh Ayachit | Status | customer review => todo |
2011-08-30 10:27 | Utkarsh Ayachit | Note Added: 0027435 | |
2011-08-30 10:27 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2011-09-02 13:44 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-09-02 13:44 | Utkarsh Ayachit | Fixed in Version | 3.12 => git-master |
2011-11-11 17:03 | Utkarsh Ayachit | Fixed in Version | git-master => 3.12 |
2012-02-08 17:28 | Utkarsh Ayachit | Status | customer review => closed |
2012-02-08 17:28 | Utkarsh Ayachit | Note Added: 0028244 |
