0012286 | ParaView | Feature | public | 2011-06-20 16:35 | 2012-02-08 17:28 | ||||
Reporter | David Partyka | ||||||||
Target Version | 3.12 | Fixed in Version | 3.14 | ||||||
Summary | 0012286: Integrate Nektar Plugin into ParaView | ||||||||
Description | Integrate building Nectar plugin and it's dependencies. > Hi Joe, > this is great! thanks for getting Berk involved. > Re: PARALLEL - i think we will not have issues or may be only minor ones, > and sequential version will be built relatively easy. > Re BLAS/LAPACK: > we can replace calls to BLAS level 1,2 and 3 with some simple routines that > will do linear algebra. > with LAPACK routines we will have to build LU factorization functions, > linear solvers, eigenvalue solvers. this is possible but i do not think it > is a good idea mainly for two reasons: > a) BLAS and LAPACK are free libraries that can be downloaded and installed > easily. > b) this will limit (or make difficult) developing future versions of our > plug-in as we would like to utilize as much as we can what is already > existing in Nektar. also Nektar's users (potential customers) can create > they own utilities and keep the same style as used in Nektar already and > assume that BLAS and LAPACK are available. > lets see what Berk can suggest, it might be that they also have some subset > of BLAS/LAPACK built-in. > Leopold > > > > > On Thu, Mar 10, 2011 at 6:42 PM, joseph insley <insley@mcs.anl.gov> wrote: >> >> Hey, Leo, >> >> I have made a PV_NEKTAR tarball, which I believe includes the minimum >> necessary code from Nektar-PARALLEL, and the actual reader plugin code. And >> wrote a short README file explaining how to build the various components. >> While doing this I took note of a few issues that will need to be addressed >> at some point. (Sooner rather than later, will be better) >> >> External dependencies: >> Blas >> Lapack >> gfortran >> >> I don't know whether these should be included in the distribution, or >> users will need to have these installed separately, or what. I'm hoping >> Berk can provide some guidance on that. >> >> MPI: >> Currently I have only been building all of the components (both Nektar and >> the plugin itself) assuming that it will be parallel. This means, I >> believe, that the reader can only work in client/server mode. Also, I >> believe that binary distributions of PV do not include MPI builds. Users >> will need to compile from source in order to get the parallel version. If >> we want users to be able to run standalone ParaView, on their laptop or >> local workstation, for example, and use the Nektar reader plugin, I think we >> are going to need to support a non-parallel version. I remember early on in >> our development, while you were visiting ANL if I remember correctly, we >> touched on this issue briefly, and decided to punt on it initially, and >> worry about it later. I think now may be the time that we need to start >> worrying about it. I will try building everything without PARALLEL=1 and >> see how far I get. But I suspect that I will run into problems before too >> long. When (if?) I do get stuck, I will poke you for help in resolving. I >> just wanted to give you a heads-up about it. >> >> joe. > > | ||||||||
Project | Kitware | ||||||||
Topic Name | 12286-integrate-nektar-plugin | ||||||||
Type | feature | ||||||||
Attached Files | PV_NEKTAR.tar.gz [^] (1,709,358 bytes) 2011-10-15 11:21 | ||||||||
(0027787) Utkarsh Ayachit (administrator) 2011-12-09 14:20 |
merged in master (wherever applicable) |
(0028236) Utkarsh Ayachit (administrator) 2012-02-08 17:28 |
Closing bugs sitting in "customer review" for a long time. |
2011-06-20 16:35 | David Partyka | New Issue | |
2011-06-20 16:35 | David Partyka | Assigned To | => David Partyka |
2011-06-22 13:54 | Berk Geveci | Target Version | => 3.12 |
2011-09-29 12:45 | David Partyka | Status | backlog => todo |
2011-09-29 12:45 | David Partyka | Status | todo => active development |
2011-10-15 11:21 | David Partyka | File Added: PV_NEKTAR.tar.gz | |
2011-12-07 17:03 | David Partyka | Topic Name | => 12286-integrate-nektar-plugin |
2011-12-07 17:03 | David Partyka | Status | active development => gatekeeper review |
2011-12-07 17:03 | David Partyka | Fixed in Version | => git-next |
2011-12-07 17:03 | David Partyka | Resolution | open => fixed |
2011-12-09 14:20 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-12-09 14:20 | Utkarsh Ayachit | Note Added: 0027787 | |
2011-12-09 14:21 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
2012-02-08 17:28 | Utkarsh Ayachit | Status | customer review => closed |
2012-02-08 17:28 | Utkarsh Ayachit | Note Added: 0028236 |
