0012243 | ParaView | Bug | public | 2011-06-03 17:18 | 2011-08-17 19:45 | ||||
Assigned To | Kyle Lutz | ||||||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0012243: Volume rendering is broken | ||||||||
Description | Trunk, Windows, local server. Open disk_out_ref.exo. All vars on. Apply. Volume render. This use to work. Nothing shows up, and I get the following: ERROR: In ..\..\..\..\src\ParaView3\VTK\VolumeRendering\vtkOpenGLProjectedTetrahedraMapper.cxx, line 237 vtkOpenGLProjectedTetrahedraMapper (07AEF100): Can't use projected tetrahedra without scalars! ERROR: In ..\..\..\..\src\ParaView3\VTK\VolumeRendering\vtkOpenGLProjectedTetrahedraMapper.cxx, line 237 vtkOpenGLProjectedTetrahedraMapper (07AEF100): Can't use projected tetrahedra without scalars! | ||||||||
Project | Sandia | ||||||||
Topic Name | 12243-fix-volume-rendering-with-global-ids | ||||||||
(0027081) Kyle Lutz (viewer) 2011-07-27 14:30 |
Merge topic '12243-fix-volume-rendering-with-global-ids' into next 7ac910b Merge topic 'sync_vtk_master-next' into 12243-fix-volume-rendering-with-global-ids dd424a4 Merge topic 'sync_vtk_master' into 12243-fix-volume-rendering-with-global-ids 64babd8 Merge topic 'random_mask_points' into 12243-fix-volume-rendering-with-global-ids d0947dd Merge topic '12402-generic-geometry-filter' into 12243-fix-volume-rendering-with-global-ids f50d63c Merge topic '12400-gradientfilter-compute-q-criterion' into 12243-fix-volume-rendering-with-global-ids 9173059 Update VTK to bring in '12243-fix-volume-rendering-with-global-ids' |
(0027118) Utkarsh Ayachit (administrator) 2011-07-29 10:40 |
Issue slated for Gatekeeper review on Jul 29, 2 pm EDT. |
(0027126) Utkarsh Ayachit (administrator) 2011-07-29 11:11 |
Verified. |
(0027164) Utkarsh Ayachit (administrator) 2011-07-29 15:03 |
Merged to master (if applicable) |
(0027382) Alan Scott (manager) 2011-08-17 19:45 |
Fixed, and works well. Tested local server, Linux, development branch. |
2011-06-03 17:18 | Alan Scott | New Issue | |
2011-06-19 18:40 | Utkarsh Ayachit | Status | backlog => todo |
2011-06-22 15:35 | Utkarsh Ayachit | Status | todo => backlog |
2011-06-27 16:00 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2011-06-27 16:00 | Utkarsh Ayachit | Project | => Sandia |
2011-06-27 16:00 | Utkarsh Ayachit | Type | => incorrect functionality |
2011-06-27 16:00 | Utkarsh Ayachit | Priority | high => normal |
2011-06-27 16:00 | Utkarsh Ayachit | Status | backlog => todo |
2011-06-29 11:42 | Kyle Lutz | Status | todo => active development |
2011-06-29 14:00 | Kyle Lutz | Status | active development => todo |
2011-07-27 11:43 | Kyle Lutz | Status | todo => active development |
2011-07-27 14:30 | Kyle Lutz | Topic Name | => 12243-fix-volume-rendering-with-global-ids |
2011-07-27 14:30 | Kyle Lutz | Note Added: 0027081 | |
2011-07-27 14:30 | Kyle Lutz | Status | active development => gatekeeper review |
2011-07-27 14:30 | Kyle Lutz | Fixed in Version | => 3.12 |
2011-07-27 14:30 | Kyle Lutz | Resolution | open => fixed |
2011-07-29 10:40 | Utkarsh Ayachit | Note Added: 0027118 | |
2011-07-29 11:11 | Utkarsh Ayachit | Note Added: 0027126 | |
2011-07-29 15:03 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-07-29 15:03 | Utkarsh Ayachit | Note Added: 0027164 | |
2011-08-17 19:45 | Alan Scott | Note Added: 0027382 | |
2011-08-17 19:45 | Alan Scott | Status | customer review => closed |
