0012230ParaViewFeaturepublic2011-05-27 12:372011-07-29 19:05
ReporterUtkarsh Ayachit
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version3.12
Summary0012230: Image Volume Rendering should support shading
DescriptionImage Volume Rendering should support shading
TagsNo tags attached.
ProjectSandia
Topic Name
Type
-  Notes
(0026636)
2011-05-27 12:40
commit b60565685a6378f2980109599aef23429edac7e3
Merge: 5a568e7 958ebfb
Date: Fri May 27 12:40:05 2011 -0400
    Merge topic '12230_shading_for_volume_rendering'
    958ebfb Fixed BUG 0012230. Image volume rendering can now support shading.
commit 958ebfba796fea310bbfed9f00bad2f4e1f1a9c8
Date: Fri May 27 12:37:17 2011 -0400
    Note that this only works with image data. Also GPU volume rendering does not
    work correctly with light kit when shading is enabled.
(0026637)
2011-05-27 13:55
There's a checkbox named "Enable Shading" on the display tab in the "Volume Rendering" section that one can check to enable shading.
(0027173)
Alan Scott (manager)
2011-07-29 19:05
Tested local server, trunk, Linux. Volume rendering didn't work remote server, but I believe that is another bug/issue/feature.
- Issue History
2011-05-27 12:37 Utkarsh Ayachit New Issue
2011-05-27 12:40 Utkarsh Ayachit Note Added: 0026636
2011-05-27 12:40 Utkarsh Ayachit Status backlog => @80@
2011-05-27 12:40 Utkarsh Ayachit Fixed in Version => 3.12
2011-05-27 12:40 Utkarsh Ayachit Resolution open => fixed
2011-05-27 12:40 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2011-05-27 13:55 Utkarsh Ayachit Note Added: 0026637
2011-06-16 13:10 Zack Galbreath Category Feature Request => Feature
2011-07-22 14:16 Utkarsh Ayachit Project => Sandia
2011-07-29 19:05 Alan Scott Note Added: 0027173
2011-07-29 19:05 Alan Scott Status customer review => closed
Powered by Mantis Bugtracker
