0012191ParaViewBugpublic2011-05-16 08:332016-08-12 09:58
Reporterjhgoebbert
Assigned ToKitware Robot
PrioritynormalSeveritycrashReproducibilityalways
StatusclosedResolutionmoved
PlatformLinux x86_64OSCentOSOS Version5.6
Product Version3.8.1
Summary0012191: Segfault reading XDMF file with XML-Links
DescriptionSegfault reading XDMF file with XML-Links like
/Xdmf/DataItem[@Name="Point Data"]
Steps To ReproduceLoad the attached file "linetest_fail.xmf" and click "Apply".
Additional InformationIn 3.10.0 it is even worse:
The test fails even, if no XML-Links are used.
TagsNo tags attached.
Project
Topic Name
Type
Attached Files? file icon linetest_fail.xmf [^] (873 bytes) 2011-05-16 08:33
-  Notes
(0037975)
Kitware Robot (administrator)
2016-08-12 09:58
Resolving issue as `moved`.
- Issue History
2011-05-16 08:33 jhgoebbert New Issue
2011-05-16 08:33 jhgoebbert File Added: linetest_fail.xmf
2016-08-12 09:58 Kitware Robot Note Added: 0037975
2016-08-12 09:58 Kitware Robot Status backlog => closed
2016-08-12 09:58 Kitware Robot Resolution open => moved
2016-08-12 09:58 Kitware Robot Assigned To => Kitware Robot
Powered by Mantis Bugtracker
