0012117 | ParaView | Bug | public | 2011-04-21 08:52 | 2011-07-22 14:15 | ||||
Reporter | Sven Buijssen | ||||||||
Assigned To | Kyle Lutz | ||||||||
Product Version | 3.10.1 | ||||||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0012117: EyeDomeLighting plugin can't be built if Qt support is disabled | ||||||||
Description | Configuring ParaView 3.10.1 with -DPARAVIEW_BUILD_QT_GUI:BOOL=OFF and -DPARAVIEW_BUILD_PLUGIN_EyeDomeLighting:BOOL=ON (for e.g. OSMesa server-only builds) leads to the following error -- Plugin: EyeDomeLighting enabled CMake Error at CMake/ParaViewPlugins.cmake:635 (QT4_WRAP_CPP): Unknown CMake command "QT4_WRAP_CPP". Call Stack (most recent call first): Plugins/EyeDomeLighting/ParaViewPlugin/CMakeLists.txt:27 (ADD_PARAVIEW_AUTO_START) This is due to Plugins/EyeDomeLighting/ParaViewPlugin/CMakeLists.txt invoking the macro ADD_PARAVIEW_AUTO_START which internally calls QT4_WRAP_CPP - which is not available in case Qt is purposely disabled. | ||||||||
Project | TBD | ||||||||
Topic Name | 12117-eye-dome-lighting-without-qt | ||||||||
(0026422) Sven Buijssen (reporter) 2011-05-03 06:31 |
The same error occurs for -DPARAVIEW_BUILD_PLUGIN_VRPNPlugin:BOOL=ON and -DPARAVIEW_BUILD_PLUGIN_VRUIPlugin:BOOL=ON. |
(0026446) Utkarsh Ayachit (administrator) 2011-05-06 10:18 |
commit 0daf57d0a30db783dda262cb6afd1077aa7c0388 Merge: a11d86a 2225953 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri May 6 10:18:23 2011 -0400 Merge topic '12117_cleanup_eyedome' 2225953 Replace RegisterRenderPassViews class with ADD_PARAVIEW_VIEW_MODULE. |
(0026933) Kyle Lutz (viewer) 2011-06-30 14:36 |
Merge topic '12117-eye-dome-lighting-without-qt' into next f24281a Add check for Qt in add_paraview_view_module() |
(0026934) Kyle Lutz (viewer) 2011-06-30 17:01 |
Also prevent the building of VRPN and VRUI when Qt is disabled. commit 65beab5a77b2a91110d80768dc9814171d9efb8f Author: Kyle Lutz <kyle.lutz@kitware.com> Date: Thu Jun 30 16:55:34 2011 -0400 Build VRPN and VRUI only if Qt is available Change-Id: Ie8194e4ca099b84190ff1892d9781661452c0060 |
2011-04-21 08:52 | Sven Buijssen | New Issue | |
2011-04-21 08:54 | David Partyka | Assigned To | => David Partyka |
2011-04-21 08:54 | David Partyka | Status | backlog => tabled |
2011-05-03 06:31 | Sven Buijssen | Note Added: 0026422 | |
2011-05-06 10:18 | Utkarsh Ayachit | Note Added: 0026446 | |
2011-06-30 12:54 | Utkarsh Ayachit | Assigned To | David Partyka => Kyle Lutz |
2011-06-30 14:28 | Kyle Lutz | Status | backlog => todo |
2011-06-30 14:28 | Kyle Lutz | Status | todo => active development |
2011-06-30 14:36 | Kyle Lutz | Note Added: 0026933 | |
2011-06-30 14:36 | Kyle Lutz | Status | active development => gatekeeper review |
2011-06-30 17:01 | Kyle Lutz | Note Added: 0026934 | |
2011-07-01 15:20 | Utkarsh Ayachit | Project | => TBD |
2011-07-01 15:20 | Utkarsh Ayachit | Topic Name | => 12117-eye-dome-lighting-without-qt |
2011-07-01 15:20 | Utkarsh Ayachit | Type | => incorrect functionality |
2011-07-01 15:25 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-07-01 15:25 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
2011-07-01 15:25 | Utkarsh Ayachit | Resolution | open => fixed |
2011-07-22 14:15 | Utkarsh Ayachit | Status | customer review => closed |
