0012115VTK(No Category)public2011-04-21 00:052016-08-12 09:55
ReporterDavid Gobbi
Assigned ToDavid Gobbi
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version5.6.0
Summary0012115: FixedPointRayCaster gives different results depending on number of threads
DescriptionThe dashboard test TestFixedPointRayCasterLinearCropped.tcl fails when run on machines with a large number of CPUs. The problem can be simulated on any machine by pumping up the number of threads.
Steps To ReproduceAdd the following lines to the beginning of TestFixedPointRayCasterLinearCropped.tcl
vtkMultiThreader multithread
multithread SetGlobalDefaultNumberOfThreads 64
Then run the test via ctest. It will produce an incorrect image.
TagsNo tags attached.
ProjectTBD
Typeincorrect functionality
Attached Filespng file icon TestFixedPointRayCasterLinearCropped.diff.png [^] (4,969 bytes) 2011-04-21 00:05
 Relationships
has duplicate 0013420closedDave DeMarle Fixed point volume mapper gives inconsistent results on multiple threads
  Notes
(0030859)
Dave DeMarle (administrator)
2013-05-28 12:13
Was fixed in commit: e4a793c47cc3
(0032185)
David Gobbi (developer)
2014-01-17 14:35
Re-opening the bug. It was reported as fixed, but it is still present.
(0032186)
2014-01-17 14:38
Apparently attempts have been made to fix this bug, but none of the developers are interested in pursuing it any further.
(0037230)
Kitware Robot (administrator)
2016-08-12 09:55
Resolving issue as `moved`.
This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page.
 Issue History
2011-04-21 00:05 David Gobbi New Issue
2011-04-21 00:05 David Gobbi File Added: TestFixedPointRayCasterLinearCropped.diff.png
2013-02-24 12:59 David Gobbi Relationship added has duplicate 0013420
2013-05-28 12:13 Dave DeMarle Project => TBD
2013-05-28 12:13 Dave DeMarle Type => incorrect functionality
2013-05-28 12:13 Dave DeMarle Note Added: 0030859
2013-05-28 12:13 Dave DeMarle Status backlog => todo
2013-05-28 12:13 Dave DeMarle Resolution open => fixed
2013-05-28 12:13 Dave DeMarle Assigned To => Dave DeMarle
2013-05-28 12:13 Dave DeMarle Status todo => active development
2013-05-28 12:13 Dave DeMarle Status active development => gatekeeper review
2013-07-10 10:17 Dave DeMarle Status gatekeeper review => todo
2013-07-10 10:17 Dave DeMarle Status todo => backlog
2013-07-10 10:18 Dave DeMarle Status backlog => tabled
2013-07-10 10:18 Dave DeMarle Status tabled => closed
2013-07-10 10:18 Dave DeMarle Product Version => 5.6.0
2013-07-10 10:18 Dave DeMarle Fixed in Version => 6.0.0
2014-01-17 14:35 David Gobbi Assigned To Dave DeMarle => David Gobbi
2014-01-17 14:35 David Gobbi Note Added: 0032185
2014-01-17 14:35 David Gobbi Status closed => backlog
2014-01-17 14:35 David Gobbi Resolution fixed => reopened
2014-01-17 14:38 David Gobbi Note Added: 0032186
2014-01-17 14:38 David Gobbi Status backlog => expired
2014-01-17 14:38 David Gobbi Resolution reopened => won't fix
2016-08-12 09:55 Kitware Robot Note Added: 0037230
2016-08-12 09:55 Kitware Robot Status expired => closed
2016-08-12 09:55 Kitware Robot Fixed in Version 6.0.0 =>
2016-08-12 09:55 Kitware Robot Resolution won't fix => moved
