0012105 | ParaView | Bug | public | 2011-04-19 04:54 | 2011-05-02 19:40 | ||||
Reporter | Sven Buijssen | ||||||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0012105: Loading state file that references an unstructured grid or uniform rectilinear grid pops up error message | ||||||||
Description | The collaboration branch merge introduced the following regression: ParaView nightly build (pv commit 0e9d5b392add10f16dd76c21c90aad50b09b6048), local server, Linux 64-bit. * Sources / Wavelet. Apply * File / Save State / filename: foo.pvsm * File / Disconnect * File / Load State / filename: foo.pvsm => the following error message is raised: VTK/Filtering/vtkDemandDrivenPipeline.cxx, line 727 vtkCompositeDataPipeline (0x34e4ef0): Input port 0 of algorithm vtkOpenGLGPUVolumeRayCastMapper(0x364b000) has 0 connections but is not optional. A similar error message is raised if the state file references an unstructured grid (Apply "Clean to Grid" before saving state): VTK/Filtering/vtkDemandDrivenPipeline.cxx, line 727 vtkCompositeDataPipeline (0x4142e60): Input port 0 of algorithm vtkUnstructuredGridVolumeZSweepMapper(0x30b4e20) has 0 connections but is not optional. This does not happen for e.g. a polygonal mesh. Neither of these errors were raised with PV 3.11.0. | ||||||||
(0026267) Utkarsh Ayachit (administrator) 2011-04-27 15:54 |
commit 1cc35e09ac564eeae612c5e07ddb96b30a8a65af Merge: cd8f060 f95a765 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Apr 27 15:53:14 2011 -0400 Merge topic '12105_fix_state_loading' f95a765 Fixed BUG 0012105. UpdatePipelineInformation() was being called incorrectly. |
(0026397) Alan Scott (manager) 2011-05-02 19:40 |
Tested trunk, windows, local server. |
2011-04-19 04:54 | Sven Buijssen | New Issue | |
2011-04-19 07:47 | Sebastien Jourdain | Assigned To | => Utkarsh Ayachit |
2011-04-19 07:47 | Sebastien Jourdain | Status | backlog => tabled |
2011-04-27 15:54 | Utkarsh Ayachit | Note Added: 0026267 | |
2011-04-27 15:54 | Utkarsh Ayachit | Status | tabled => @80@ |
2011-04-27 15:54 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
2011-04-27 15:54 | Utkarsh Ayachit | Resolution | open => fixed |
2011-05-02 19:40 | Alan Scott | Note Added: 0026397 | |
2011-05-02 19:40 | Alan Scott | Status | @80@ => closed |
