0012032 | ParaView | Bug | public | 2011-03-31 09:28 | 2011-04-25 12:06 | ||||
Reporter | David Partyka | ||||||||
Product Version | 3.10 | ||||||||
Target Version | 3.12 | Fixed in Version | 3.10.1 | ||||||
Summary | 0012032: VISITBRIDGE_USE_FILE is configured to point to build tree in installed ParaViewConfig.cmake | ||||||||
Description | From Stephane Ploix It seems that there is a pb with the installation rules of VisItBridge : The file ParaViewConfig.cmake points to the build directory for the file VisItBridgeUse.cmake, and this file is not copied in the install dir. The offending line in ParaViewConfig.cmake is SET(VISITBRIDGE_USE_FILE "/path/to/build/dir/Utilities/VisItBridge/VisItBridgeUse.cmake") The pb is that we cannot use an installed version of paraview to build anything with if the build dir is not there | ||||||||
(0025983) Stephane P (reporter) 2011-03-31 10:58 |
In addition, VISIT_CMAKE_DIR is set to the source tree in the ParaViewConfig.cmake, as SET(VISIT_CMAKE_DIR "/path/to/source/dir/Utilities/VisItBridge/CMake") |
(0026167) David Partyka (developer) 2011-04-11 14:23 |
My self and Rob made a couple of fixes in ParaView and VisItBridge to get this working. commit d11642ebdf8b71ec43f4e9c35a6c40e6d9179502 Author: Robert Maynard <robert.maynard@kitware.com> Date: Fri Apr 8 16:27:25 2011 -0400 Update the VisItBridge SHA1 for static compilation and install rule fixes. commit beea0576dd249589caaa7a0d381abafa87d5b19c Author: David Partyka <david.partyka@kitware.com> Date: Fri Apr 8 08:16:27 2011 -0400 Correctly configure VisItBridge ParaViewConfig variables in install tree. |
(0026255) Alan Scott (manager) 2011-04-25 12:06 |
Trusting Dave's changes. |
2011-03-31 09:28 | David Partyka | New Issue | |
2011-03-31 09:28 | David Partyka | Status | backlog => tabled |
2011-03-31 09:28 | David Partyka | Assigned To | => David Partyka |
2011-03-31 10:58 | Stephane P | Note Added: 0025983 | |
2011-03-31 11:24 | Utkarsh Ayachit | Target Version | 3.10.1 => 3.12 |
2011-03-31 11:24 | Utkarsh Ayachit | Target Version | 3.12 => 3.10.1 |
2011-04-11 14:14 | Utkarsh Ayachit | Target Version | 3.10.1 => 3.12 |
2011-04-11 14:23 | David Partyka | Note Added: 0026167 | |
2011-04-11 14:23 | David Partyka | Status | tabled => @80@ |
2011-04-11 14:23 | David Partyka | Fixed in Version | => 3.10.1 |
2011-04-11 14:23 | David Partyka | Resolution | open => fixed |
2011-04-25 12:06 | Alan Scott | Note Added: 0026255 | |
2011-04-25 12:06 | Alan Scott | Status | @80@ => closed |
