0012031 | ParaView | Bug | public | 2011-03-31 09:21 | 2011-05-02 21:34 | ||||
Reporter | Ricardo Reis | ||||||||
Assigned To | Robert Maynard | ||||||||
Platform | X86_64 | OS | Linux | OS Version | Debian | ||||
Target Version | Fixed in Version | 3.10.1 | |||||||
Summary | 0012031: .sos reader for Ensight Master files doesn't work properly | ||||||||
Description | When loading a .sos file (Ensight Master) access to the variables isn't correct. Ie, after loading outline is correctly seen. If a "slice" is made only " Solid Color cellNormals vtkCompositeIndex " show up in the "Display" dialogue box. | ||||||||
Steps To Reproduce | I can provide a set of files upon request. | ||||||||
(0025981) Robert Maynard (developer) 2011-03-31 09:40 |
To clarify the issue, the dataset in question has a property named "pr". It shows up in the object inspector but isn't on the resulting multiblock. If you load each block individually the property is found and properly loaded. Confirmed that this bug exists in 3.8.1 and 3.10.X |
(0026007) Robert Maynard (developer) 2011-04-01 09:30 |
Merge topic 'ensight-case-property-bug' 9219fdf Fix Bug 0012031. Sos files with a single time step wouldn't load properties. |
(0026412) Alan Scott (manager) 2011-05-02 21:34 |
Tested local server, Windows, Trunk. |
2011-03-31 09:21 | Ricardo Reis | New Issue | |
2011-03-31 09:40 | Robert Maynard | Note Added: 0025981 | |
2011-03-31 09:40 | Robert Maynard | Assigned To | => Robert Maynard |
2011-03-31 09:40 | Robert Maynard | Status | backlog => tabled |
2011-04-01 09:30 | Robert Maynard | Note Added: 0026007 | |
2011-04-01 09:30 | Robert Maynard | Status | tabled => @80@ |
2011-04-01 09:30 | Robert Maynard | Fixed in Version | => 3.10.1 |
2011-04-01 09:30 | Robert Maynard | Resolution | open => fixed |
2011-05-02 21:34 | Alan Scott | Note Added: 0026412 | |
2011-05-02 21:34 | Alan Scott | Status | @80@ => closed |
