0012007ParaViewBugpublic2011-03-23 22:462011-07-29 10:43
ReporterPat Marion
Assigned ToAlan Scott
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version3.10
Target Version3.10.1Fixed in Version3.12
Summary0012007: Python trace hangs during interaction with animation view
DescriptionReported on the paraview mailing list under the subject: [Paraview] Error using Python Trace in PV3.10-RC1
I found a problem using the Python Trace functionality with PV3.10-RC1. I've
loaded in a dataset and started a trace. I then proceeded to take a slice
through the dataset, which worked fine. Next, in the animation view, I added
a cue based on the x-value of the slice origin. Double-clicking on the
scalar bar gives the pop up window to set the start and end values. At this
point, I can't change any of the values and ParaView just hangs. This only
appears to happen with the variables that are essentially vector components
(Normals and Origin); I can modify the scalar options without it crashing.
I did manage to get around the problem by adding one of the vector
components as a track BEFORE starting the trace and then deleting it
immediately. I can then start the trace, add the track again (or any of the
options), modify its values without ParaView crashing.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0026136)
Pat Marion (reporter)
2011-04-07 11:03
With this bug fix, you should be able to record a trace of animating the Origin property of a slice plane, using any of the 3 components.
(0026408)
Alan Scott (manager)
2011-05-02 21:22
Sweet!
Tested local server, Windows, trunk.
 Issue History
2011-03-23 22:46 Pat Marion New Issue
2011-04-07 11:03 Pat Marion Note Added: 0026136
2011-04-07 11:03 Pat Marion Status backlog => @80@
2011-04-07 11:03 Pat Marion Resolution open => fixed
2011-04-07 11:03 Pat Marion Fixed in Version => 4.0
2011-04-07 11:03 Pat Marion Target Version => 3.10.1
2011-05-02 21:22 Alan Scott Note Added: 0026408
2011-05-02 21:22 Alan Scott Status @80@ => closed
2011-05-02 21:22 Alan Scott Assigned To => Alan Scott
2011-07-29 10:43 Utkarsh Ayachit Fixed in Version 4.0 => 3.12
