0011976 | ParaView | Bug | public | 2011-03-16 14:19 | 2016-08-12 09:58 | ||||
Summary | 0011976: Calculator errors with autoapply on | ||||||||
Description | The calculator is showing errors when used with autoapply turned on. * Trunk, Windows, local server. * can.exo, all vars on, apply. * Turn auto apply on. * Calculator filter. * In the equation, type 1e7*(), then use the mouse to place the curser between the ( )'s. Next, click on Scalars and try to put in coordsX. The following error will occur: ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax error: expecting a variable name; see position 5 ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax error: expecting a variable name; see position 5 Warning: In ..\..\..\..\src\ParaView3\VTK\Graphics\vtkArrayCalculator.cxx, line 401 vtkPVArrayCalculator (06D35EE8): An error occured when parsing the calculator's function. See previous errors. ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax error: expecting a variable name; see position 5 ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax error: expecting a variable name; see position 5 Warning: In ..\..\..\..\src\ParaView3\VTK\Graphics\vtkArrayCalculator.cxx, line 401 vtkPVArrayCalculator (06D35EE8): An error occured when parsing the calculator's function. See previous errors. ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax error: expecting a variable name; see position 5 ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax error: expecting a variable name; see position 5 Warning: In ..\..\..\..\src\ParaView3\VTK\Graphics\vtkArrayCalculator.cxx, line 401 vtkPVArrayCalculator (06D35EE8): An error occured when parsing the calculator's function. See previous errors. ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax error: expecting a variable name; see position 5 ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax error: expecting a variable name; see position 5 Warning: In ..\..\..\..\src\ParaView3\VTK\Graphics\vtkArrayCalculator.cxx, line 401 vtkPVArrayCalculator (06D35EE8): An error occured when parsing the calculator's function. See previous errors. ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax Error: missing closing parenthesis; see position 12 ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax Error: missing closing parenthesis; see position 12 Warning: In ..\..\..\..\src\ParaView3\VTK\Graphics\vtkArrayCalculator.cxx, line 401 vtkPVArrayCalculator (06D35EE8): An error occured when parsing the calculator's function. See previous errors. ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax Error: missing closing parenthesis; see position 12 ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1461 vtkFunctionParser (0C5D30B8): Syntax Error: missing closing parenthesis; see position 12 Warning: In ..\..\..\..\src\ParaView3\VTK\Graphics\vtkArrayCalculator.cxx, line 401 vtkPVArrayCalculator (06D35EE8): An error occured when parsing the calculator's function. See previous errors. | ||||||||
Project | Sandia | ||||||||
(0036437) Alan Scott (manager) 2016-07-13 20:32 |
Still bad. Tested with 5.1.1, Linux. |
(0037936) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-03-16 14:19 | Alan Scott | New Issue | |
2011-03-16 14:22 | Alan Scott | Description Updated | |
2011-09-01 10:56 | Utkarsh Ayachit | Project | => Sandia |
2016-07-13 20:32 | Alan Scott | Note Added: 0036437 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037936 | |
