0011862ParaViewBugpublic2011-02-15 12:192016-08-12 09:58
ReporterHsadek
Assigned ToKitware Robot
PriorityhighSeverityminorReproducibilityalways
StatusclosedResolutionmoved
PlatformLinuxOSOS VersionRed Hat
Product Version
Summary0011862: Paraview lighting Vs Command line - Tracing 3.10
DescriptionI am using Paraview 3.10.0 64-bit. When I save the animation to png and
do a trace to python code, the lighting effect from the outcome of
Paraview differs from the output of the Command-line.
You can check the difference through those 2 links:
http://www.4shared.com/photo/AJZDTH_t/commandline.html [^]
http://www.4shared.com/photo/YE4P7IsN/Paraview.html [^]
Thanks,
TagsNo tags attached.
Project
Topic Name
Type
-  Notes
(0037925)
Kitware Robot (administrator)
2016-08-12 09:58
Resolving issue as `moved`.
- Issue History
2011-02-15 12:19 Hsadek New Issue
2016-08-12 09:58 Kitware Robot Note Added: 0037925
2016-08-12 09:58 Kitware Robot Status backlog => closed
2016-08-12 09:58 Kitware Robot Resolution open => moved
2016-08-12 09:58 Kitware Robot Assigned To => Kitware Robot
Powered by Mantis Bugtracker
