0011854 | ParaView | Feature | public | 2011-02-14 15:16 | 2011-08-17 20:07 | ||||
Assigned To | Kyle Lutz | ||||||||
Target Version | 3.12 | Fixed in Version | 3.12 | ||||||
Summary | 0011854: Add multiple variable selection to AMR Contour | ||||||||
Description | We need to add multiple variable support for the AMR Contour, and probably AMR Clip filters. I have a user that is looking at an object, such as a car. Every part of the car is a different Material Volume Fraction (engine, transmission, frame, alternator - around 15-20 of these), and he would like to be able to select them in one step, rather than one by one, over and over again. A example would be Dave's small CTH dataset - we want to select the ball and plate with one filter. What I want is basically the code in the Material Interface Filter. | ||||||||
Project | Sandia | ||||||||
Topic Name | 11854-multiple-amr-contour-arrays | ||||||||
Attached Files | bug.patch [^] (735 bytes) 2011-07-28 15:44 [Show Content] | ||||||||
(0027096) Utkarsh Ayachit (administrator) 2011-07-28 15:42 |
Look at vtkPVAMRDualClip. We need to do similar for the contour. |
(0027097) Utkarsh Ayachit (administrator) 2011-07-28 15:44 |
Look at attached patch. It's a bug in vtkPVAMRDualClip, don't repeat the same in your version :). I am committing a fix for vtkPVAMRDualClip but it may take a while for it to show up on master. |
(0027224) Kyle Lutz (viewer) 2011-08-04 11:28 |
Merge topic '11854-multiple-amr-contour-arrays' into next 78030f5 Add the ability to use multiple input arrays in AMRDualContour |
(0027239) Utkarsh Ayachit (administrator) 2011-08-04 18:08 |
Developer note: Issue slated for gatekeeper review on Aug 7, 2 PM EDT. |
(0027258) Robert Maynard (developer) 2011-08-05 10:32 |
verified that this works. |
(0027280) Utkarsh Ayachit (administrator) 2011-08-05 15:55 |
Merged into master (if applicable) |
(0027384) Alan Scott (manager) 2011-08-17 20:07 |
Oh, that is sooo excellent. Tested local server, development branch, Linux. |
2011-02-14 15:16 | Alan Scott | New Issue | |
2011-02-14 15:19 | Alan Scott | Target Version | => 3.10.1 |
2011-02-14 15:19 | Alan Scott | Description Updated | |
2011-02-15 15:55 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2011-02-15 15:55 | Utkarsh Ayachit | Status | backlog => tabled |
2011-03-31 11:24 | Utkarsh Ayachit | Target Version | 3.10.1 => 3.12 |
2011-07-27 22:00 | Alan Scott | Project | => Sandia |
2011-07-27 22:00 | Alan Scott | Type | => incorrect functionality |
2011-07-28 15:42 | Utkarsh Ayachit | Note Added: 0027096 | |
2011-07-28 15:42 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Kyle Lutz |
2011-07-28 15:42 | Utkarsh Ayachit | Status | backlog => todo |
2011-07-28 15:42 | Utkarsh Ayachit | Target Version | => 3.12 |
2011-07-28 15:44 | Utkarsh Ayachit | Note Added: 0027097 | |
2011-07-28 15:44 | Utkarsh Ayachit | File Added: bug.patch | |
2011-08-04 10:50 | Kyle Lutz | Status | todo => active development |
2011-08-04 11:09 | Kyle Lutz | Topic Name | => 11854-multiple-amr-contour-arrays |
2011-08-04 11:28 | Kyle Lutz | Note Added: 0027224 | |
2011-08-04 11:28 | Kyle Lutz | Status | active development => gatekeeper review |
2011-08-04 11:28 | Kyle Lutz | Fixed in Version | => 3.12 |
2011-08-04 11:28 | Kyle Lutz | Resolution | open => fixed |
2011-08-04 18:08 | Utkarsh Ayachit | Note Added: 0027239 | |
2011-08-05 10:32 | Robert Maynard | Note Added: 0027258 | |
2011-08-05 15:55 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-08-05 15:55 | Utkarsh Ayachit | Note Added: 0027280 | |
2011-08-17 20:07 | Alan Scott | Note Added: 0027384 | |
2011-08-17 20:07 | Alan Scott | Status | customer review => closed |
