0011775 | ParaView | Feature | public | 2011-01-28 15:03 | 2014-02-04 21:29 | ||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0011775: 2d axis is confusing | ||||||||
Description | It is confusing how to turn on the show axis for a 2d view. Lets add a note in the display tab, for 2d views, that tells a user to go to the Edit View Options. An example dataset is sources/ mandlebrot. | ||||||||
Project | Sandia | ||||||||
(0028634) Alan Scott (manager) 2012-05-22 22:44 |
After a lot of discussion, I believe that consensus is that we should have the same user interface for the 3d cube axis and the 2d axis. To a user it is the same thing, with or without a Z dimension. |
(0032200) Utkarsh Ayachit (administrator) 2014-01-21 12:02 |
This was fixed a while ago. 2D view is not longer a separate type of view hence we use the same "Show Axes" check box of the display panel to show the cube axes. |
(0032270) Alan Scott (manager) 2014-02-04 21:29 |
Nice. Tested master, local server, Linux. |
2011-01-28 15:03 | Alan Scott | New Issue | |
2011-09-01 10:56 | Utkarsh Ayachit | Project | => Sandia |
2012-05-22 22:44 | Alan Scott | Note Added: 0028634 | |
2014-01-21 12:02 | Utkarsh Ayachit | Note Added: 0032200 | |
2014-01-21 12:02 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-01-21 12:02 | Utkarsh Ayachit | Fixed in Version | => 4.1 |
2014-01-21 12:02 | Utkarsh Ayachit | Resolution | open => fixed |
2014-01-21 12:02 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-01-21 12:02 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-02-04 21:29 | Alan Scott | Note Added: 0032270 | |
2014-02-04 21:29 | Alan Scott | Status | customer review => closed |
