0011709 | ParaView | Bug | public | 2011-01-16 19:20 | 2011-05-02 21:17 | ||||
Reporter | Isam Yamashita | ||||||||
Assigned To | Robert Maynard | ||||||||
Product Version | 3.8.1 | ||||||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0011709: The close button does not terminate the paraview process during animation. | ||||||||
Description | When I pressed the close button at the top-right of the window while animation was playing, the gui application was terminated but its process was still running. If paraview was playing an animation loop when the button was pressed, the process continued running until I killed it manually. When I used the‘EXIT’in the Edit menu, both the gui application and the process were terminated normally. This problem occurred on both linux and windows. | ||||||||
Steps To Reproduce | 1.Play an animation loop. 2.Press the close button at the top-right of the window while the animation is playing. 3.Check the process manager, you will see paraview process is still running. | ||||||||
(0026166) Robert Maynard (developer) 2011-04-11 12:50 |
author Robert Maynard <robert.maynard@kitware.com> Thu, 7 Apr 2011 14:41:33 +0000 (10:41 -0400) 0f428bc Animations now stop when you request the player to go to a new frame. b86f78a ParaView now properly quits while an animation is still playing. |
(0026407) Alan Scott (manager) 2011-05-02 21:17 |
It is properly closed now. |
2011-01-16 19:20 | Isam Yamashita | New Issue | |
2011-04-07 08:25 | Robert Maynard | Assigned To | => Robert Maynard |
2011-04-07 08:25 | Robert Maynard | Status | backlog => tabled |
2011-04-11 12:50 | Robert Maynard | Note Added: 0026166 | |
2011-04-11 12:50 | Robert Maynard | Status | tabled => @80@ |
2011-04-11 12:50 | Robert Maynard | Fixed in Version | => 3.12 |
2011-04-11 12:50 | Robert Maynard | Resolution | open => fixed |
2011-05-02 21:17 | Alan Scott | Note Added: 0026407 | |
2011-05-02 21:17 | Alan Scott | Status | @80@ => closed |
