0011696 | ParaView | Feature | public | 2011-01-14 09:32 | 2016-08-12 09:58 | ||||
Reporter | Stephane P | ||||||||
Priority | normal | Severity | minor | Reproducibility | N/A | ||||
Summary | 0011696: add a hint tag to specify which array to use for default color of the output | ||||||||
Description | Add a "Hint" tag that can be used in the xml files to specify a given array (typically, this would point to the "ActiveScalars", "ActiveVectors"... ). This array will then be used to color the output by defaut. hard-coding the array name could aslo be supported. | ||||||||
Additional Information | typical xml could look like : <Hint> <ColorByAttribute attribute_association="point" <-- can be "point" or "cell" attribute_type="Vectors" <-- can be "Vectors" or "Scalars" attribute_name="blah" <-- hard code the array name / not compatible with the "attribute_type" tag. attribute_component="Magnitude"> <-- can be "Magnitude" (by default) or the component number </Hint> | ||||||||
Project | ParaViS | ||||||||
(0037911) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-01-14 09:32 | Stephane P | New Issue | |
2011-01-14 09:43 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2011-01-14 09:43 | Utkarsh Ayachit | Status | backlog => tabled |
2011-01-14 09:43 | Utkarsh Ayachit | Target Version | => 4.0 |
2011-06-23 11:43 | Utkarsh Ayachit | Project | => ParaViS |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037911 | |
