0001167VTK(No Category)public2004-09-15 10:142016-08-12 09:54
ReporterGoodwin Lawlor
Assigned ToWill Schroeder
PrioritylowSeverityfeatureReproducibilityalways
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0001167: Change vtk3DWidget::SizeHandles() to a public method
DescriptionAt the moment, widgets resize their handles after they are transformed in the scene. If the user zooms in/out, the widget handles become disproportionately big or small compared to the viewport. If vtk3DWidget::SizeHandles() was changed to a public method it could be used as a callback, observing the renderer's StartEvent, so that widget handles are always correctly sized. This could be implemented in C++ inside the widgets themselves or left to the developer to do within their application. If implemented, this would probably make the SizeHandles() calls inside the *ButtonUp callbacks redundant.
TagsNo tags attached.
Project
Type
-  Notes
(0036752)
Kitware Robot (administrator)
2016-08-12 09:54
Resolving issue as `moved`.
This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page.
- Issue History
2016-08-12 09:54 Kitware Robot Note Added: 0036752
2016-08-12 09:54 Kitware Robot Status expired => closed
2016-08-12 09:54 Kitware Robot Resolution open => moved
Powered by Mantis Bugtracker
